This could be dangerous...
Discussion in 'Amp Tech Center' started by JSMac, Aug 5, 2021.
  1. JSMac
    JSMac Tele-Holic
    Front Range Colorado
    ...if you didn't know what you were looking at.
    There's 311vdc at that transformer. I guess it's not really a problem with the partial back panel installed, but still. I've seen old radios set up like that but never a guitar amp. How common was that?
  2. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    isn't that called field-coil speaker?
  3. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    No, that's just the OT. A field coil speaker has 4 wires; 2 for the voice coil & two for the, you know, field coil, which also serves as the power supply choke and co-incidentally a power interlock so the thing won't be run without the speaker. There's a plug on the wire with two larger pins for polarity.
    Telekarster likes this.
  4. Zoso420
    Zoso420 Tele-Meister
    Chicago
    One way to get the OT away from the
    PT
    2L man likes this.
  5. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    Looks like you've got a two conductor power cord on that thing. That was common.
  6. JSMac
    JSMac Tele-Holic
    It is fused but I intend to put a three prong cord on it. Looks like the filter caps have been replaced but that’s about it.
  7. Wally
    That bare fuse on the bottom of the chassis situation would be changed if I were going to work on it. Is this a home brew or does it have a
    Manufacturer name on it? It is a PTP amp for the most part, is it not?
  8. JSMac
    JSMac Tele-Holic
    What is PTP?
    The badge on the front says Tempo. I can't find any info on this particular amp but some reference to some tempo solid state amps. Maybe affiliated with Univox. 004.JPG 005.JPG
    Telekarster and Sidney Vicious like this.
  9. JSMac
    JSMac Tele-Holic
    There is a Schematic on the back panel.
    TwoBear likes this.
  10. tubedude
    tubedude Tele-Meister
    east georgia
    It's a darwinian puzzle.
    JSMac likes this.
  11. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    Reminds me of that song, "The back's off the telly and the wires are live ... don't touch it", just before that puff of smoke from burnt fingers.
    That is not the primary reason to fit a back panel, it was for the increase in tone.
    It only becomes dangerous if people poke their fingers in it when it is running.
  12. Wally
    PTP…point to point….no circuit board. I think I see a couple of terminal strips, but I see a lot of PTP connections.
    Interesting amp.
  13. JSMac
    JSMac Tele-Holic
    Yes, PTP wiring. It’s a pretty nice sounding amp, other than some AC noise. It’s bright and chimey and pretty clean. Not much dirt when cranked and not very loud. The tremolo is as nice as I’ve heard.
    Wally likes this.
  14. Wally
    JSMac, after you get that recapped and serviced; try this. Use another instrument cable to jumper the two unused inputs. This will decrease the resistance on the input signal and give the circuit a boost.
  15. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Back to original question, it was very common to mount the output transformer on a speaker frame. We also had Lawn Darts, single circuit drum brakes, smoking in hospitals...
    mrriggs, dan40, Timbresmith1 and 2 others like this.
  16. Wally
    In reality, that frame mounted OT presents no more danger than does any other speaker lead connection. The only speakers that have some added safety there are the spring tension connectors as used on EVs with the insulated caps that one pushes down to insert the speaker wire. I have never thought about touching those connections, though.
    That fuse on the underside has live wall voltage.
    One of the more dangerous amps I have been around was a Univox. I forgot that there was a section of live circuit that was bare on the underside of the chassis. I reached under there while holding my guitar, which was plugged into the amp, to jiggle a tube to see if it was the source of some noise. Lol….I touched that circuit. My butt went straight up about a foot off of the chair in which I was seated! DO NOT REACH UNDER A UNIVOX OR THIS AMP WHILE IT IS LIVE!
    TwoBear and Telekarster like this.
  17. Telekarster
    Telekarster Friend of Leo's Gold Supporter
    Earth
    Hey Wally, any chance this amp has the "death cap" situation in it?
    EDIT: Didn't see your recent post... I'm presuming it does then?
  18. zook
    zook Friend of Leo's
    Cochise, AZ
    Wally and Telekarster like this.
  19. Telekarster
    Earth
    Ahhh..... and there we have it....
  20. JSMac
    JSMac Tele-Holic
    I did see the death cap on the schematic and will be removing that as well as replacing the fuse holder and adding a three prong power cord.
    Wally likes this.
