Thinline with P90 in the neck position
Discussion in 'Other T-Types and Partscasters' started by Gunny, Jul 22, 2021 at 8:48 AM.
  1. Gunny
    Gunny Tele-Holic
    Newcastle, Ontario Canada, near Toronto
    My friend, an avid guitar player and jam space host, has a large number of electric guitars. Most of them are semi-hollow Epiphones, his general preference.
    He's looking for a Thinline Tele fitted with a P90 in the neck and a standard Tele bridge pup. It could be a Fender or Squier, no preference on that detail. He's not looking for any P90s in the bridge location.
    Does such a guitar exist? Is there a particular model name he should be searching under? Thanks.
    Old Plank and Boreas like this.
  2. rand z
    rand z Friend of Leo's
    trumansburg, ny
  3. Gunny
    Gunny Tele-Holic
  4. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I have never seen one, but I like his thinking. Easy enough to make it happen with a little surgery.
    I would probably start with a Squier CV Thinline and swap the top. Great guitars.
    naveed211 likes this.
  5. Boreas
  6. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    It seems Fender is missing out on an opportunity. I don’t see any offerings from them even with the Squier brand, that have a single coil bridge and other than a regular or wide range HB in the neck. It would make a nice setup if they offered one, sorta like the Custom, with either a P90, firebird, or miniHB in the neck, along with a single coil and vintage-style bridge and a pickguard sized right for the neck. And maybe a cost effective (trial) if using Squier and offshore labor.
    Or maybe that’s an idea G&L could seize!
    Has anyone here adapted a factory Fender or Squier (not a custom made one) to have a similar neck and bridge pickup, and a bridgeplate, in a configuration like this?
    I have contemplated doing that with my Squier Custom which currently has 2 P90s - putting a single coil and vintage (or similar) bridgeplate in it.
    Boreas likes this.
  7. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    There's the Fender Aerodyne family from some years ago, has an arched top although not a thinline...
    Old Plank and yegbert like this.
  8. JeffBlue
    JeffBlue Tele-Afflicted
    Southern California
    You can build one exactly the way you want. I prefer Warmoth.
    I realize that the P90 is in the middle position, but that is what I wanted. Warmoth made this body to my specs and did a splendid job. The sound hole is my idea and custom cut by me as well as the rout on the pickguard
    StewMac Alder thinline body converted to a brass top by me.
    Not a thinline, but Warmoth routed the body how I wanted
    Edenhaus body that was custom routed and custom homemade copper pickguard. It's not a thinline, but the same goes for custom routing
    Old Plank, FenderLover and wabashslim like this.
  9. Freeman Keller
    Boreas and FenderLover like this.
  10. Gardo
    Gardo Tele-Afflicted Silver Supporter
    Lancaster Pa
  11. Old Plank
    Old Plank Friend of Leo's Gold Supporter
    Maine USA
    Ah yes I was "that far"from buying one at the time, cool guitar and think I remember there was an accompanying Aerodyne bass as well.
  12. wabashslim
    Sonorous Desert
    Me too, I played one in a store a few times and almost took the wallet out but passed once more. A few days later it was gone - last one.
    Later I decided to try a P90 in one of my existing Teles & wasn't impressed. Those Aerodynes were poplar, I believe, and weight-relieved. They had Strats & P-basses too, and I think the basses kind of caught on.
    Old Plank likes this.
  13. LGOberean
    LGOberean Doctor of Teleocity
    Corpus Christi, Texas
    "Thinline w/ P-90 in the neck"?
    You have my attention. :twisted:
    That Schecter PT Special looks great, and I don't know how they sell it for $600, but it is a solidbody, not a thinline.
    I have a solidbody tele with a P-90 in the neck, and the body is mahogany. (The day I ordered it I guess I was trying to answer the question "What do you get when you cross a tele and an LP Special?")
    This tele is both the Beauty and the Beast. The latter partly because of the P-90 growl, but mostly because it weighs 9 lbs. 2 oz. I wouldn't mind the same configuration, but with the lighter weight that would come from a thinline construction, or chambered.
    WTRT and Chicago Matt like this.
  14. schmee
    It's an easy do on a Tele with a pick guard. I made one, but eventually went to a Mini in the neck.
    Second from the right in this old pic: Thinline Body, 57 Strat neck, all else custom
    dougstrum likes this.
  15. Freeman Keller
    I learned something yesterday wiring the guitar that I'm currently building. It is a tele-clone and will have two P90's. I'm using one of the Oak four way switches (because I happened to have one). The Oak switch will do either parallel or series connections but you have to bring both leads from the neck pickup as well as a separate ground. The P90's that I'm using don't have this - I had to take one apart and add the extra wire.
    No biggie and wouldn't happen with a three way switch, but it did catch me unaware.
  16. tfarny
    tfarny Poster Extraordinaire
    Hudson Valley, NY
    It's no help to the OP, most likely, but this is my most-played guitar, a Warmoth body / neck "carved top" thinline with a Lollar 50s P90 neck and Duncan JD in the bridge. I've had it for a decade and while I have played many others and many have come and gone, this has never been the wrong tool for a job.
    BB likes this.
  17. tfarny
    Hudson Valley, NY
    PS a drill and a forstner bit and a new pickguard could turn just about any standard tele into a P90 tele.
  18. richiek65
    richiek65 Friend of Leo's
    Sydney NSW Australia
    I'm hearing very good things about Vintage brand
    Or a G&L Tribute, thinline with a neck HB, easily swapped out for a P90. I know of at least one person on here with a G&L supporting a Seymour Duncan PRails in the neck, and it sounds righteous
  19. WTRT
    WTRT TDPRI Member
    Maryland
  20. Gardo
    Lancaster Pa
