Thinline Tele build
Discussion in 'Tele Home Depot' started by preeb, Feb 24, 2011.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Thanks mgdesigns!
    September may be a good time. I'm invited to a wedding so might extend the visit to do a little "system clean up" trip.
  2. preeb
    Sonoran Desert
    Lamb Khabab is not just food... it's a spiritual gathering.
    Phase one:
    It starts with 2 lbs of roughly ground Rump top and 1lb of Lamb fat.
    I boil the fat and keep only the liquid oil. I let it cool down and add it to the ground Rump. 1 tea spoon of Cinnamon and 2 tea spoons of salt, Chopped onion and Parsley are added. I mix the entire thing well with my hands (a lot of oily fun!) and make the Khabab balls. They need to stay in the fridge for a couple of days for best results.
    Phase 2:
    Driving deep in the forest to find a good spot. Once found we unpack and set up a camp (-;
    Phase 3:
    Khabab balls are charbroiled on the grill until the outside is dark and crisp (from the oil) and the inside is pink and juicy. Fresh pita bread and Humus is optional and work very well with the Khabab (especially if warmed a little on the grill).
    Phase 4:
    Taste and call everyone to eat as much as they can because you need to make sure they will be fed up by the time the real meat is made (-;
    Phase 5:
    Real meat. Picanha... It's my favorite. Just a little ocean salt added.
    Very serious stuff. Eat till you drop.
    Last phase:
    Look at the world from this angle for at least a couple of hours with icy cold bear in your hand and one of the girls swinging you from side to side.
  3. MRJ.
    MRJ. Tele-Meister
    West End, NC
    I see. The Picanha looks very much like a nice cut of sirloin. Now you've got me wanting steaks. Oh yeah.
  4. '59_Standard
    '59_Standard Tele-Holic
    Worldwide
    Come on, Gil, April Fools day was yesterday. There's no way you, AND a Polar Bear will fit in that hammock after eating all that food! :)
  5. RyanThePirate
    RyanThePirate TDPRI Member
    Perth, Western Australia
    I'm hungry :p
  6. Cain61
    Cain61 TDPRI Member
    Joseph, Ore.
    Gil, I really like the alternative method you used to bring out the flame on the tele. However, what would you do with a blue or green top? Use lighter colored flakes?
  7. preeb
    Sonoran Desert
    Never thought of using those colors... but yes.
  8. ASC67
    ASC67 Friend of Leo's
    Minneapolis, MN.
    Love it ! Absolutely beautiful flame on that top.
  9. SixShooter
    SixShooter Friend of Leo's
    Cincinnati
    That's very smart! Thank you for the info.
  10. preeb
    Sonoran Desert
    Thanks Steve!
    I did the final clear coat and will assemble it soon.
  11. ordenes10
    ordenes10 Tele-Meister
    germany
    i never tought that isreal is that green.very nice place.
  12. Cain61
    Cain61 TDPRI Member
    Joseph, Ore.
    Thanks for answering my question. By the way, I appreciate your dedication to tradition regarding colors. :D
  13. preeb
    Sonoran Desert
    Most don't...
    Some even can't spot it on the map (very tiny...) or think it's all desert and camels... LOL
  14. Voyce
    Voyce TDPRI Member
    Israel
    i also have had talks with people who didnt think israel had computers and what not.. only sand haha.
    אחרי שאני רואה את כל העבודות המשובחות שלך.. אני חושב שכדאי לבקש.
    אני רוצה לקנות צוואר חדש לסטראט שלי. יש מצב שאתה מכין לי צוואר שמתאים לסטראט אבל עם הדסטוק של טלקסטר?
    ואם כן אז כמה זה יעלה?
    תודה רבה!
  15. preeb
    Sonoran Desert
    Questions in languages older than 3000 years should be directed through PM's (-;
  16. Voyce
    Voyce TDPRI Member
    Israel
    haha alright ...
  17. preeb
    Sonoran Desert
    I got a sign this morning... this guitar will turn out great (-;
    Lacquer is cured. time to buff it but I will not introduce it to the large buffing wheel because the film is exceptionally thin and I don't want to risk buff-throughs...
    I'm shooting for a low gloss finish to keep the antique vibe but I still want it to shine to some degree so here's how I do it.
    I'll use the old school circular buffer to have better control of the buffing and start with the coarse red compound @ 1500RPM to remove any surface imperfections
    Once the top is perfectly smooth and even, like that
    I place a silicone rubber on the table and flip it (the top is now very slippery and needs a grab)
    back is done the same way
    and the sides as well
    At this point the guitar shines but not too much... I need to take it up just a notch to get it to that vintage patina blurry shine, so I skip the medium and fine compounds and go directly to the swirl remover. It will remove any swirls from the coarse buffing but also add the required shine that I'm looking for
    I apply it with the buffing disk @ 2500 RPM because this material needs a little heat to do its job well. Like that
    Time to clean the F holes from any over spray and buffing residue. Masking tape removed
    and I carefully sand the F holes walls with a 220 grit stick
    Body cleanup is done with a nice blurry shine (-;
    Remember this chunk of wood? well... it's out of jail now.
    Body assembly time. I start with the Switchcraft short toggle switch.
    First I run a curved stainless steel strip from the switch hole and out through the F hole
    Switching harness is pulled to it's location
    Switch nut screwed and the harness is run through the channel to the control side
    PU attached to a heavy mild steel bridge. It's a vintage correct base but 60% heavier for the needed mass.
    Since this build is based on a 51 Broadcaster (templates, neck shape, pu's... ) I'll use the old slotted screw set for that "old meets new" vibe (-;
    Bridge screws are waxed before installation
    PU's installed and the leads are extracted through the lower F hole
    Broadcaster input jack ferrule is heated and pushed in
    Circuit is soldered (Master volume and Master tone with a 0.033MFD cap)
    Packed tightly
    and the pots are set in their holes
    I tighten the pot nuts and allow the pots to swivel, forcing the wiring up and away from the F hole area
    for a clean look so they will not be visual
    Strap buttons installed and a pair of heavy knurled 1950 Chrome plated brass Broadcaster knobs. Done with the body for now...
    Catalin switch tip... of course (-;
    Neck is buffed in the same way as the body
    Note the Early 50's contours
    The decal was buried under the clear coat and since I make it from nitrocellulose is melted in nicely
    Fingerboard is cleaned and soaked with hot Carnauba/bee's wax for about an hour.
    This board very 3D looking and has flames too (-;
    When the wax is completely absorbed I wipe the excess and it's done
    Neck attached to the body
    with 2" NOS slotted screws and a heavy plate
    Nut is notched
    I cut the string slots in the 1951 V way. Like that
    Nut is filed to height and rounded
    I know the nut setup looks like a quick job with a couple of photos... but it's not.
    I really take my time doing it right; It affects playability a lot!
    String tree installed.
    For this guitar model I prefer to have it closer to the nut for a tighter attack.
    Guitar is complete and sounds seriously good (-;
  18. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    Beautiful , gorgeous , stunning !
  19. ASC67
    Minneapolis, MN.
    Awesome !
  20. SSO720
    SSO720 Tele-Meister
    Knoxville TN
    Absolutely BEAUTIFUL !!! How does it sound???
