tim0101010
I'm hoping for some wisdom from some of the experienced tube amp repairers/builders out there.
There is a broken Fender Champ clone (but with SS rectifier) available that I was thinking about buying. A Champ seems like a good place to start. I’m no expert with analog circuits, more of a tinkerer. But I've been doing some reading up on tube circuits (also have an EE degree), so I'm hoping that there's a good chance that I can avoid electrocuting myself.
The only info available is that the fault is described as ”won’t power on and the tubes don’t glow”. So it looks like the fuse might be blown, but it would be good to know the most likely causes for this. If its the power transformer then it is probably not economical to buy. However, if it's a solder joint, 6V6 or audio transformer then it could be a good project.
Does anyone want to hazard a guess and put some odds on the likely causes? (The amp is only a year or two old I believe)
Thanks
Thanks
