Thinking in building a tweed amp - 1st timer
Discussion in 'Shock Brother's DIY Amps' started by tube.tone, Jul 23, 2009.
  1. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Fullerton, CA
    When idling, but what about under load/working conditions?
    I know the cathode voltage will swing a decent bit under load, so wouldn't the resistor under load make more of a difference?
    I've been trying to figure out true wattage/dissipation for cathode biased amps and then the Load Line sheets come in... at which point, I forget about it.
    This is also part of the confusion in many amp makers calling cathode biased "Class A."
    After all of the reading, at the end, I'm still confused :)
  2. tube.tone
    tube.tone Tele-Meister
    Northeast
    Hello, I am back with the first pictures. I have received the kit Yesterday and i started to take the first steps. Although, I already have a few questions for the seniors:
    1- When I installed the power transformer, I noticed there's a red and blue wire, and 2 white and red wires (one is labeled with #6). Were do they go?
    2- One of the two red wires from power transformer to rectifier is labeled with a #5 , but wiring diagram shos that they connect to #4 and #6, any
    clue? Please see attached photo.
    3- Using the socket key as a reference can you help to identify the pins (1,2,3,...)? I prefer to double check before start soldering.
    Thanks
    putting the chassis together:
  3. ThermionicScott
    CID
    I think the numbers on the transformer wires are just for identification -- not for which tube pins they connect to. They "key" in the tube base goes between pins #1 and #8, if that helps. (Pity they don't number the pins on the sockets like they did in the old days!)
    - Scott
  4. tube.tone
    Northeast
    Thanks! what you guys usually do with unused wires from power transformer? Tape, heat-shrink?
    I have started the soldering in the chassis...
  5. ThermionicScott
    CID
    Coolness! Now's the time to decide how you want to wire the heaters... if you want to keep the heater wires down against the chassis, you'll want to put them in first. If you want the signal wires to hug the chassis, and prop the heater wires into the air (like some blackface amps), then obviously do them last. ;)
    Re: unused wires. I bend each one over, and roll several layers of electrical tape over it so it won't make contact with anything, then bundle it with other unused wires and tuck them away.
    - Scott
  6. tube.tone
    Northeast
    Update,
    Here is a pic of filament wires route planing, I order tohave room to work I will have to solder it after circuit board is instaled:
    Circuit board ready to solder:
    I have opted for TDA filter capacitor:
    Orange drop for all other capacitors and carbon comp resistors, so far I have decided to respect the original values:
  7. tube.tone
    Northeast
  8. sjhusting
    sjhusting Tele-Afflicted
    Germany
    Connecting the 100-ohm resistors like that is fine. It elevates them above ground by the cathode voltage, which reduces hum.
    In tweed chassis, I prefer to tuck the heater wires against the lip of the chassis; this keeps them further from everything else.
    Also, if you are interested in keeping as close as possible to original parts, if those ODs are 715s, that type of capacitor didn't exist in 1957; you would be closer with a 716 or a Mallory. But I don't think it makes much difference. Others do.
    steven
  9. celeste
    celeste Friend of Leo's
    Maryland
    716's are basically 715's with copper leads. 225's would be more original.
  10. sjhusting
    Germany
    Right. Faulty memory.
  11. tube.tone
    Northeast
    Hey guys, thanks for the imput. The amp is going faster than first thought! I had to place an order for more wire. I have also ordered another pilot lamp assembly, I was not pleased with the one that came with kit.
    Here is a few more pictures,
    Instaling the controls and jacks:
    Full Chassi waiting for the extra wire:
    Cheers
  12. tube.tone
    Northeast
    Sorry for the spam guys! Today is a very importanday day, the chassi received a new house...
    Best
  13. ThermionicScott
    CID
    Looks very nice and tidy so far! Spam away! :cool:
    - Scott
  14. tube.tone
    Northeast
    Thanks! It's not dificult at all, I'm just concerned about the testing procedures... I am sure I'll need help.
    I'll keep you postest
    Best
  15. Jelle
    Jelle Tele-Meister
    Netherlands
    Looks great and thanks for posting; I love pics :p
  16. tube.tone
    Northeast
    Thanks for the support; this forum is an inspiration for me.
    I have purchased this kit with a European power transformer. Actually, it has, 120v, 220V, 240v taps. I will be using 220V tap. I’ll be moving back to Portugal (my origin Country) next Month.
    For now I have soldered the 120V, so that I can perform the first tests. Later on, when I back to Europe I assume that I just have to desolder the 120V and solder the 220V tap. Is this correct? Should I have any other concern?
    Also, I would like to give my positive feedback on Weber Kit (rest in peace) is a great value for your buck, to say the least. I have ordered almost complete; cabinet, board, transformers, hardware and 12A150 speaker.
    As I have mentioned before, I placed a separate order or capacitors and resistors (Orange Drops, TAD and carbon comp resistors). Also, I ended up using a different cloth wire supplied by Tube Depot (who also does a great service).
    Ted Weber Kit has arrived very well packed, chassis is all chromed and looks pristine, it came with all perforations needed for board and transformers. The cabinet itself is beautiful, strong construction, well finished and ready to instal the chassis. No extra work required, except thight a few screws.
    So far, needless to say that I am very happy,
    Regards
  17. sjhusting
    Germany
    When you move to Europe, change the mains fuse to 1/2 what it is now.
    steven
  18. tube.tone
    Northeast
  19. sjhusting
    Germany
    The red/blue lead is for the negative bias voltage, if you are building a fixed-bias amp. You are not building one, though, your amp is cathode bias, so you don't use the red/blue lead.
    The red/white leads are used if you want lower HV - the Weber transformer puts out 340-0-340 and 270-0-270, and you use the ones you need for the voltage you need.
    In both cases, clip the lead so there is no bare wire, and shrink-wrap it so that there is no chance of being suprised by a few hundred volts. Make sure the leads are secured so they do not flop around in the chassis.
    steven
  20. ThermionicScott
    CID
    "NC" = not connected. :D
