Engine Swap
Let me see if I can tunnel in….
AT&T jerked my daughter around with that extender crap for months. She finally relented and put one in. Still got crappy coverage.
Just wanted to check in....
We've had ATT fiber for about a month now. Speed is great, coverage is poop. If I'm more than 15 feet away from the modem, I get marginal connections and lots of dropouts.
So, to that end, I called tech support today. Here's how it went down:
Me: I'm getting poor coverage
ATT: Let's run a test - yes, you're getting poor coverage. We suggest that you sign up for extenders for an extra $15 per month.
Me: Its a 1400 square foot house, I shouldn't need extenders. I suggest you send a tech out right away to fix the issue.
ATT: Hold on - there's an "adjustment" we can do on our end to your modem to improve coverage. Would you like us to try this?
Me: OK, let her rip.
Long story short, they throttle the range on their end to try to get people to sign up for extenders. I now have strong coverage in the entire house. Cost to me $0/tech visits 0. Just putting this out there for anyone else who might run into this "issue".
That doesn't make sense in total but I understand it all more in tech terms.Just wanted to check in....
Fiber people: what was the hardware install? Do they have to dig up your yard, drill holes in your house, etc? Once it gets to your house does it utilize the coax already in yours walls?
it will vary. They break the cable out to Cat6 at the street here... which is no big deal, you can easily run gig speed over cat6, so, you would never know a difference.Fiber people: what was the hardware install? Do they have to dig up your yard, drill holes in your house, etc? Once it gets to your house does it utilize the coax already in yours walls?
if you look at the back of the router (or somewhere on the router) it will give you the info you need to log into your router and turn up the wifi, and do lots of other things that can be helpful (like increase your dhcp range) change the wifi password etc.Just wanted to check in....
