The Virtues of the Humble EQ Pedal
Discussion in 'Pedal/Effects Owners Clubs' started by scottser, May 29, 2020.
  1. scottser
    scottser Friend of Leo's
    dublin
    So yesterday I put away the marshall and plugged in my VHT Special 6, prompted by the amount times that I've recommended it on here to folks looking for a smaller amp.
    I usually use a tiny pedalboard with it, just a tuner, EQ and reverb. The circuit has a number of power-scaling options plus a pentode/cathode switch in each setting. I've always found that rather using another drive pedal, an EQ is the perfect compliment to an amp with one tone control as you can get all of your creamy blues or raspy hendrix tones with the push of a few faders. Clean boost? No problem. Chimey sparkle? No problem. Want to use an acoustic instrument in there? Fill your boots.
    The say 'less is more' but an EQ is the key to getting a whole lot more for just a little less less.
  2. Gibson
    Gibson Friend of Leo's
    Hong Kong
    Wouldn't it be far simpler to buy boutique pickups, a replacement custom speaker, jeweled titanium saddles, and 50-year-old paper caps soaked in myrrh? I mean whatever sounds good to you, but you're clearly overthinking the whole process, imo. ymmv.
  3. dlew919
    dlew919 Poster Extraordinaire
    Sydney
    I’ve just put mine on the board I use for my solid body mandolin. Takes the bite out.
    Others use them as boosters or drive pedals. Very versatile
    scottser likes this.
  4. scottser
    dublin
    given the love for champs on here i would have thought that if you were going to run a pedal into one, an EQ would be more than enough.
    dlew919 likes this.
