The Special Tiger
Discussion in 'Tele Home Depot' started by MM73, Mar 24, 2016.
  1. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Not much to say here.
    Lined it up, drilled it, and routed it.
    I did need to kiss the jack bore face with a 5/8 forstner to get the jack recessed a bit into the curved surface.
    Will probably do the same for the strap buttons to avoid that shoddy look of a flat piece attached to a curved surface.
    Pots are just what I had handy to check fit.
  2. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Had to make a template to make a clean looking cover recess for the control cavity.
    After that was done, the rest moved along nicely.
    Aside from pass thru holes for wiring, this body is ready for paint : )
    CraigB, richa, John Nicholas and 5 others like this.
  3. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    ...finish work o_O
    First real use of the airbrush and compressor.
    Somehow clogged the medium nozzle when spraying the shellac base, and I can’t reassemble it!
    So, tried the fine tip nozzle opened up.
    This is 6% Mixol white in Behlens lacquer thinned 2:1; first coat.
    Went on thin and even sprayed at 30 psi. But it took a lot of passes.
    I think the fine tip may not be great for spraying lacquer.
    Will try to get the medium tip cleaned and see if I lets me increase coverage on each pass. The shellac in alcohol didn’t need as many passes.
    ...and lots of fuzzies to fine sand out before the next coat.
  4. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Got the medium nozzle back together.
    After using it to spray shellac, I took the needle and nozzle apart and soaked in lacquer thinner to clean.
    It swelled the o-ring in the nozzle!
    I let it dry, and it went back together easy-peasy.
    Spraying with the medium nozzle was better.
    Getting closer.
    ...but the dust and fuzz is killing me!
    I also have a heavy nozzle on order; will see if that helps me lay down base coats a bit more efficiently with the airbrush.
    Not worried so much about time, but don’t want to overwork the little compressor.
    CraigB, Jim_in_PA, Barncaster and 2 others like this.
  5. John Nicholas
    John Nicholas Friend of Leo's
    Poughkeepsie, NY
    Hey Mark,
    It's looking really good!
    Never thought an air brush would have a wide enough fan to paint a guitar body. This is where the fuzz is coming from. As for the dust it takes a great deal of cleaning the shop to avoid the dust!
    Is there any reason you did not get a full size spray gun??
    I have to say the finish you are getting looks much smoother then my rattle can applications. Mine need quite a bit of wet sanding to make then even and flat.
    Keep up the great work!
    Barncaster and MM73 like this.
  6. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    The airbrush is definitely not ideal for base coats, but with patience, it does a great job.
    The fan with the medium nozzle isn’t much bigger than 2” diameter.
    I picked up the airbrush and compressor because I have a strong interest in graphics work...and I hoped the setup would be good enough for larger jobs. Truthfully, I had been overwhelmed by all the options for a full size gun. Figuring out what I needed for detail spraying was more straightforward.
    Again, not quite ideal for large jobs, but I’ve learned a lot. My decision on other spray gear will be more informed.
    I’ll be moving on to clear coats and graphics without any sanding.
    Well, I’ll knock the fuzz off once more.
  7. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Been noodling on what I want to do graphic-wise on this one, and am ready to get started.
    Trying to stay ahead of the colder weather settling in around here.
    Plenty of warm fall days for spraying before I get chased indoors.
    I have a couple coats of clear over the white now.
    Sizing and layout for graphic starts today.
  8. John Nicholas
    Poughkeepsie, NY
    Mark, it's looking really good!
    Can't wait to see what you do with the graphics!!
  9. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Scattered parts, notes, password, and time have left me frozen in time.
    First, a bit of liquor store patriotism.
    Second, guitar crafting in progress.
    Hope all has been well with everyone!
    Next, gotta see if Jupitor’s DPP 335 is finished.
  10. El Tele Lobo
    El Tele Lobo Friend of Leo's Silver Supporter
    I was wondering where you went, friend. Glad to se you back and back at work!
    MM73 likes this.
  11. Mat UK
    Mat UK Tele-Afflicted
    London, UK
    Back in the saddle! What's the plan?
  12. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Yes, the plan.
    12th fret markers to be replaced with a strip of ebony.
    The pic shows a piece of electrical tape I had used to check aesthetics before I routed away the maple.
    All kinds of trouble making the template for the body graphic.
    Lots of little curves to be cut, and i am making a mess of it all.
    Gonna try and find someone with a cricut machine that I can borrow.
    I did polish up the body.
    Use of the airbrush for the base white coat resulted in what I might describe as a thin skin finish - glossy, but the poplar grain can be seen thru it. Spray cans have always left me with a very opaque finish over poplar in the past.
    More work and pics to come : )
  13. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Nothing is ever easy.
    The ebony is tough on the plug cutter and can break apart while drilling.
    I marked the direction of grain on markers to keep ‘em inline with the grain on the neck, but am having a hard time keeping the grain perfectly straight.
    Good-ish
  14. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Waiting for glue to dry, then I’ll trim it up.
    This view made for a better pic, it is clamped up now.
    1/4” fret markers from ebony continue to drive me crazy...brittle little buggers.
    Jim_in_PA and Barncaster like this.
  15. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Progress.
    Nut slot cut, fret markers in, and 12” radius sanded in.
    Side markers and neck mount holes next. Then frets.
    Gotta get back to the graphic template...tedious!
  16. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    I offered a drive to the beach or camping.
    They wanted to stay home. o_O
    Ended up being a productive weekend in the shop.
    Had some Warmoth 6105 wire...
    Frets are seated well and the level and fret rocker doesn’t suggest much leveling in my future : )
    Sanded through 220.
    ...and getting really difficult to procrastinate that graphic template for the body.
  17. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Darkened up the neck a bit.
    • 3 or 4 base coats of clear Behlens
    • 4 - 6 coats of tinted laquer (2 oz clear + 2 drops transtint brown)
    I didn’t keep track of the tinted coats; just walked it to the shade that I liked.
    Applied super thin with my airbrush.
    Will get more clear over it, then move on to decal work.
  18. MM73
    MM73 Tele-Afflicted
    South Lyon, MI
    Peek-a-boo!
    Finally getting some graphics work done!
    CraigB, Mat UK, AAT65 and 2 others like this.
  19. John Nicholas
    Poughkeepsie, NY
    Very nice!!
    Glad you're back at it!
    MM73 likes this.
  20. Mat UK
    London, UK
    Amazing!
    Inspiring me to get back to building...
    MM73 likes this.
