The Prince of Wails: KLD Kit
Discussion in 'Shock Brother's DIY Amps' started by Randy Jones, Mar 30, 2020.
  1. Randy Jones
    Randy Jones TDPRI Member
    San Francisco
    Hello shock brothers,
    First time working on an amp, so brace for newb questions. I ordered the Princeton amp kit from KLD (trem, no reverb). Some things of interest: it's diode rectified, two 12AX7s and two 6L6's, it has a "boost switch" which cuts out the tone controls and is supposed to provide a tweedish sound. Yah, we'll see. After ordering it appears this is highly similar to the Ceriatone princeton kit. So, looks like a copy of a copy. Not sure
    Kit arrived and i'm now trying to layout the chassis. Chassis is aluminum 11x7x2 which seemed plenty big, but now seems tight! I think it will still work. Here's the view looking into the chassis. Output transformer is surface mounted. Power transformer has one bell in the box with a the wad of wires coming out one side. Before i start drilling holes, how does this arrangement seem to you experienced folks? Basically, i'm trying to keep the guitar signal far from the powery bits.
    Screen Shot 2020-03-30 at 10.09.52 AM.png Screen Shot 2020-03-30 at 10.10.43 AM.png
    JohnnyCrash likes this.
  2. Whatizitman
    Whatizitman Friend of Leo's
    WV
    Did the chassis come with it? I figured KLD recommends their USA partner for chassis. They are pre-drilled, and I believe the layouts are all pretty similar. I'm not knowledgeable to say for certain. But I would go by their layout design as close as possible, unless someone here recommends otherwise. KLDs are 'clones' but not really super close to spec to famous amps. They are made very modular - probably to save costs across the line. I would consider using ceriatone's layouts as reference only.
    Randy Jones likes this.
  3. Randy Jones
    San Francisco
    No, i ordered the blank canvas aluminum chassis separate. Went this route because... i'm a glutton for punishment? Also, the suggested chassis overlapped with their other amp designs as you note, meaning there is a hole for a rectifier tube etc that i wouldn't need.
  4. Randy Jones
    San Francisco
    Any glaring issues with my layout plan? Mostly i want to avoid noise. My understanding is the main source of noise is having the guitar signal/preamp section too close to the power section.
    Does it help to add wires to the pic above... digital soldering is much easier to undo :)
  5. Lowerleftcoast
    Lowerleftcoast Tele-Holic
    california
    Position of the transformers can cause noise. Hopefully someone more experienced than I can chime in if they see a problem.
    One thing that looks out of place is the location of the bias pot.
  6. Randy Jones
    San Francisco
    Thanks for looking! The bias pot came on the pre-soldered P2P board. It’s oriented vertically in reality.
  7. Randy Jones
    San Francisco
    C3F411B4-3AA6-442B-A188-F65119D5897B.jpeg One small step for a man. One even smaller step in an amp build.
  8. tubeswell
    tubeswell Friend of Leo's
    NZ
    The tranny placement looks okay. 6L6 output tubes want some space between them to help with heat dissipation. (Like ‘1 x tube diameter’)
  9. Randy Jones
    San Francisco
    Thx for the feeback! Switched to a 17x7 chassis for more flexibility and ease of maneuvering for newbie.
  10. Paul-T
    Paul-T Tele-Meister
    London
    Is there an advantage/disadvantage to have the PT near the main board and the OT further away?
  11. Randy Jones
    San Francisco
    I do not know. I put them there for 3 reasons:
    1) The wires coming out of the PT are shorter and connect to the right half of the board, so i put it closer.
    2) the PT is super heavy. Having nearer the middle will hopefully stabilize the weight
    3) Visually i kinda liked the alignment.
    There, now you know you're dealing with a total luddite. Thankfully i haven't cut the top of the chassis yet, so now is the time informed decision making. That's where y'all come in.
