I've done a couple of posts on this on the "What's on your workbench...", but as I am getting a bit more progress on it lately I figured I'd do a full thread on it.
To summarize where I'm up to: Last year I made my first guitar (Tele) out of an old church pew end. I had a small piece left over.and thought why not give a small (starting at the 5th fret basically, so tuned ADGCEA) acoustic a try. Re sawed it into top and bottom and carved an arch onto the top. The sides are black walnut soaked overnight, bent on a copper pipe heated with a soldering iron then clamped into a mold. Cut some kerfing (by hand - very tedious) and some bracing. Neck and end block are from some maple. I've just today routed the binding channels for the maple binding I will add.
The neck will be a 5 piece laminated maple/walnut perhaps with carbon fibre rod in place of a proper truss rod. I am planning a dove tail neck joint. Not too sure about the fretboard. Some kind of f holes are planned too..... It's been the best part of 18 months to get to this point, hopefully not that long again before completion.....
