Here is what I’m planning for a future build. No idea if it will work but it looks right on paper.Can you elaborate? What should I do?
Your single coils will be out of phase, not cool unless it's what you're going for
I've yet to take the step of making a neck. Intimidated by it. Maybe having the right tools would help me take that step!I went and found my order from 2015 and back then I got a large coarse and a small fine for 80 bucks total.
Now that same pair is $180
I'd love to own more. Should have bought them in 2015! But a hand stitched rasp is the bees knees if you've never used one! I've shaped every neck I've ever made with those two rasps as well.
It might be time. I have all the tools, except rasps. It would be nice to be able to say, "I made that guitar," instead of "I still buy my necks."Maybe it's time! Tools are key. You'll need a way to route a truss rod slot, carving tools, fretting tools, and fret leveling tools.
But to be perfectly honest I don't think you should be intimidated by it. I've always found neck shaping to be very forgiving (with my rasps). You get a hump or a flat spot somewhere and it'll come out easier. I have a much harder time with bodies if I get a flat spot around the edges or something else weird happens.
Well, in my experience that is out of phase,both ways. But apparently in single coil mode you've grown to like that. The neck looks normal but you've done the bridge exactly backwards (depending how you wire it I suppose) but regardless in single coil mode you have a north and a south. In how I was taught that's out of phase when BOTH are selected. Now I often do that myself but to get a "humbucker" with the neck and bridge pickup but my both is in series in this case although with a standard switch it tends to have Strat quack which also sounds goodCan you elaborate? What should I do?
I think a lot of people here have produced a good body, finish, wiring, etc., but may be hesitant to do a neck. Or, maybe I'm the only one. In any case, I'd be eager to see how you do what you do!If it helps you out, not that there aren't plenty of neck build threads on here, I can go a lot more detailed with pictures and descriptions here when I build my necks.
I still buy my fretboards preslotted and preradiused. I have the ability to do it myself, but I need more practice before I really start doing it.
Well, in my experience that is out of phase,both ways. But apparently in single coil mode you've grown to like that. The neck looks normal but you've done the bridge exactly backwards (depending how you wire it I suppose) but regardless in single coil mode you have a north and a south. In how I was taught that's out of phase when BOTH are selected. Now I often do that myself but to get a "humbucker" with the neck and bridge pickup but my both is in series in this case although with a standard switch it tends to have Strat quack which also sounds good.
I found all this by being a Strat modder (hey, we all have secrets lol). From removing one pot and adding one switch I had "normal" and neck/bridge and middle as humbucker. A very minimal mod with BIG tone changes lol. I learned from Bill Lawrence but hey, I could be wrong but I'd build my humbuckers identical and wire them different if I wanted the sound you seem to be going for
Then again I thought the Gibson Marauder was the finest electric I ever played, but the Gibson faithful didn't agree![]()
Steve. You might want to make the bridge pickup north coil and the neck pickup south coil active when in single phase. The bridge pickup north coil will give better output than the south coil.
Apparently I got confused by the north/south crap. Regardless I would wind them identical and install them the way I wantThat hasn't been my understanding. I had a strat for several years (in also a strat tinkerer) that I wired up with the Brian May wiring scheme. So it had phase reversal switches for every pickup combo. So I know what out of phase pickups sound like. It can be fun, but it is not a desirable tone and definitely not achieved by RWRP pickups.
Don't take my word for it though, here's a screenshot from seymour Duncan's website
Out Of Phase Pickups | Seymour Duncan
Guitar pickup polarity: guitar pickups are like flavours of food. You want to wind up with chocolate and peanut butter, not chocolate and onions.www.seymourduncan.com
And any time I've run into a phase issue it's been just that. Flip the polarity, fixed. Flip a wire on one of the pickups, fixed.
RWRP is about hum cancelation, but doesn't cause phasing issues.
So VERY nice
Sorry for the derail on the pickups, just got confused on that bridge pickup. I'd make it identical to the neck pickup then just turn it around. That's exactly what Gibson did with the PAF and the results speak for themselves. Not sure I'd do what they've done with the coil splits. Even if you find the correct diagrams most sounded bleh except one. And I don't remember that model![]()
