The Emeraldcaster Project (aka Son of Meloncaster)
Discussion in 'Tele Home Depot' started by Buckocaster51, Oct 1, 2007.
  1. Buckocaster51
    Iowa USA
    Admin Post
    One final little adjustment and we can take off that sliver...
    as always, paying attention to the direction the cutter is going
    although I managed to cut out the outside of the body before that bearing collet came loose...
    didn't quite make the control cavity! :oops:
    But I guess that is what this stuff is for.
    The "problem area" is small...and will be hidden under the control plate, and layers of flake and clear...but it would still be nice if it wasn't there...
    There are those bodies with no binding again!
  2. axmaker
    axmaker Tele-Holic
    Oakley, CA
    just noticed your signature:
  3. strat-o-teleman
    strat-o-teleman Tele-Meister
    Spring Hill, TN
    I hope none of those "problem areas" involved any fingers:!::eek::!: Bondo doesn't work too well on those...ask me how I know;)
  4. Texas Special
    Texas Special Tele-Meister
    Up The Junction, England
    Bodies with no binding? Perhaps a liason with some paisley paper?
  5. Buckocaster51
    Iowa USA
    Admin Post
    You kids are just too good!
    What did I say to give it away?
  6. Scotty Lonesome
    Scotty Lonesome Tele-Holic
    El Cerrito, CA
  7. Texas Special
    So, what colour paisley you going for? Or, do we guess?
  8. jb12string
    jb12string Tele-Afflicted
    South Central PA
    Paisley Paper, wasn't that like, 35 pages ago
    ETA: Actually, it was back in the 50 something pages, August of 08, I checked :D
  9. Buckocaster51
    Iowa USA
    Admin Post
    black on silver sparkle
    but go ahead and guess...
  10. Buckocaster51
    Iowa USA
    Admin Post
    But in the meantime, I made a few changes to the pattern for the sound hole for the Mk II.
    The changes aren't really visible
    here is the Mk I after the CA is GOOD and DRY
    tonight it doesn't look as bad as I remembered it...
    I think it will be worth the effort to finish it out and see what it will look like
  11. Buckocaster51
    Iowa USA
    Admin Post
    Turns out the actor, Meinhardt Raabe, was born over near Madison WI. Not too far from here really. He passed away last spring. Certainly one of my most memorable characters from tWoO.
  12. Buckocaster51
    Iowa USA
    Admin Post
    We can knock off some of the rough corners with a homemade sanding stick...
    then screw that bad boy back down
    then start putting the outside binding on...which will really be the inside binding on the guitar
    working from both corners around to the other corner
  13. Willandthewonts
    Willandthewonts Tele-Meister
    Palms, California
    That was my 7th grade Earth Science book! haha
  14. Buckocaster51
    Iowa USA
    Admin Post
    Let me tell you, that is the best MS/HS Earth Science book around.
    I've used at least 4 different editions of it.
    Good eye!
  15. Willandthewonts
    Palms, California
    Absolutely! I still remember most of that stuff... it was a wonderful book and I was lucky enough to have an absolutely FANTASTIC teacher who is now a great friend.
  16. Buckocaster51
    Iowa USA
    Admin Post
    We still be working our way around that f-hole to be...
    interesting look
  17. mudbean
    mudbean Friend of Leo's
    SoCal Semi-Desert Semi-Paradise
    Well, I had no idea who they are, but I sure do see some flagrant disregard for the "No Shorts On Stage" rule!
    Youse guys is rowdy scofflaws, you is.
    mud
  18. Buckocaster51
    Iowa USA
    Admin Post
    Rowdy...yes!
    Scofflaws...yes!
    Total disregard for "No Shorts On Stage" rule...YES!
  19. Buckocaster51
    Iowa USA
    Admin Post
    Finished putting the inside binding on last night, but had a few gaps that needed filling.
    Soaked some binding in acetone and stuffed it in where it needed to be.
    now need to figure out how to get it off the form...
    and see what happens to its shape when I do.
  20. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    I'm on pins and needles. Awaiting your successful next step.
