The DIY Scatter Pickup Winder
Discussion in 'Tele Home Depot' started by Scatter Lee, Oct 25, 2010.
  1. Scatter Lee
    Scatter Lee Friend of Leo's
    follow the buzzards
    time for me to make a pickup winder, first i need to make a counter and have just enough junk around to make one, like this old calculator to start with
    got the back off
    and poked around to find the equal button spot
    then cut the magnetic switch off of a schwinn bicycle computer
    and soldered it in there
    closed it up
    hit + 1
    and when the switch passes the magnet the calculator goes up one
    here it is in action :cool:
    now i have to get the switch on the winder, i worked on it a little today, still have a couple pieces to make, no plans, making it up as i go along, in my head i can see it working :cool:
    :twisted::p
  2. Engraver-60
    Engraver-60 Friend of Leo's
    Brentwood, TN
    And while winding the Scatter Wound Pickup, you can reel in a small mouth bass for dinner! Love it as always. You are the Rube Goldberg of Telecaster Builders (at I mean that in a very kind admiring way).
  3. Nick JD
    Queensland, Australia
    With built in automatic traversal!
    You can't call it the Scatter winder...
  4. Bob_H
    Bob_H Tele-Meister
    San Diego, CA
    Scattercaster maybe?
  5. Dababy
    Dababy Tele-Meister
    Northeast Ohio
    I tried that same thing with the calculator and then with a pedometer. I wasn't able to get either one to count fast enough. I know others have been able to do it though so I'm looking forward to see how it goes!
  6. melomanarock
    melomanarock Tele-Holic
    Argentina
    that's amazing.. really smart thinking man.. seems like u could remove the handle on the reel and use a hand drill to avoid hand lavor
  7. flatfive
    flatfive Friend of Leo's
    Monterey, CA
    Okay, Mr. Scatter Lee, we know you're clever, but how did you
    know that the signal from the bicycle computer would be
    compatible with the calculator?
    :confused:
    Fess up.
  8. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    Its a reed (magnetic) switch, so it has no "signal" as such.
    Scatter, I knew I'd love this before I even clicked it. I was waiting for the twist and it came with the fishing reel. Fan-bloody-tastic as always.
    The only downer is, no matter how precise you make it, your PU's are always gonna be Scatter wound.
    The price of success I suppose! :cool:
  9. oramac7891
    oramac7891 Friend of Leo's
    Wow??? I would have not even known where to begin.
  10. cjburr
    cjburr Tele-Meister
    thank you Scatter Lee, I'm sitting here in Afghanistan marveling at your ingenuity. As I live in Edgewater Fl. not far from you I'm definitely going to look you up when I get done over here to shake your hand. Your threads have given me much entertainment and many smiles while I've been here.
  11. Scatter Lee
    follow the buzzards
    i dont know what tranversal is but it does go forward and back a 1/4" just right for a p90 i hope,
    maybe call it the scatter lee pickup winder :p
    yeah not as fast as i hoped, about 150 rpm, with 5.2 to 1 ratio thats about 1923 cranks for a p90, i'll probably just crank it faster and count myself
    you got that right
    got the magnet on, another action video
  12. Nick JD
    A thing that makes the wire traverse from one side to the other giving a clean, neat wind - like nearly all factory pickups. I love that of all people, a man called Scatter is making non-scatter pickups :D:cool:.
  13. Nash
    Nash Tele-Holic
    Fullerton, CA
    What if you put the magnet on the handle instead of the reel?
    If you already know that it's a 5.2 to 1 ratio then you just divide the number of winds you want by 5.2 and make that the target for your calculator's readout.
  14. Casual_Reader
    Casual_Reader Tele-Holic
    Ohio
    nash beat me to it...
    but if the speed of the calculator continues to be a problem, there's this idea using the computer - which might be faster and buffer "clicks":
  15. MatthewK
    MatthewK Tele-Holic
    Hobart, Australia
    Scatter if civilisation collapsed, and people survived on their wits and ingenuity, I would fully expect you to emerge as the leader of North America.
  16. flatfive
    Monterey, CA
    Okay, that makes sense.
    Still, how does one know that wiring a switch to the 'equals'
    button is going to result in the calculator incrementing when
    the switch is toggled?
  17. kwerk
    New Zealand
    Apologies to Scatter for jumping in again, but this method is reasonably well documented and can be found in many places on the net. The button on a calculator is essentially just a single piece of conductive material that closes a circuit. By adding 0+1, then pressing the equals button, you will get the expected result:1. Subsequent presses of the equals button will add another 1 to the last equation (on most calculators). By replacing the button with a switch (in this case a simple magnetic switch) the same result can be achieved.
    Reed switches are most typically found in alarm systems and are usually used on windows, where the circuit completes with the removal of the magnet. Reed switches are available in both varieties (presence of magnet closes circuit or alternatively absence of magnet closes circuit, the more typical alarm approach).
    Just to jump in on another aspect, I gotta add a +1 (ironically) to the suggestion of hooking the reed switch to a mouse button and using the calculator function on the computer. As suggested the buffering abilities of the computer should allow for a higher degree of accuracy and reliability.
  18. Scatter Lee
    follow the buzzards
    excellent idea :idea:
    this is awesome, i'll try it today and if the computer blows up i'll use the magnet on handle method :cool:
    :twisted::cool:
  19. ImmortalSix
    ImmortalSix Tele-Meister
    Charlottesville, VA
    Awesome ingenuity and execution as usual - you da man!
  20. garymaddox
    garymaddox Tele-Afflicted
    Foat Wuth, Texus
    You should have left the counter on a bicycle and stuck the winder to the back wheel. Ride to town for a 6 pack and you got a bridge pickup to boot!
    Weeman333 likes this.
