The different 'stripes' of Peavey TransTubes?
Discussion in 'Amp Central Station' started by LGOberean, Jul 1, 2009.
  1. Dave_O
    Dave_O Friend of Leo's
    offline and IRL
    Great little amps for rehearsal and small gigs. I use my Rage (with a 10" Eminence) quite a lot for small rooms
    Go to the Mojo Bros myspace (link under the signature) and listen to it live- guitars were MIJ 62RI Strat, MIJ 52RI Tele and '81 Ibanez Blazer for slide.
    So wildschwein, another Sandgroper... (ex-patriot here)
    I spent quite a lot of my mis-spent youth throwing large screaming motorcycles around the Mundaring Weir Road. Didn't fall off. Much...:D
  2. postjob62
    postjob62 Tele-Holic
    FL
    Has anyone tried the Peavey Nashville 112 steel amp?
    Made in USA, clean for miles, great spring reverb, effects loop, power amp in and other cool features. Did I mention loud? Real loud!
    It has a certain natural warmth and compression that sounds good to my ear anyway. It's real clean, but put a JD-10 or Bad Monkey in front if you need to and it really sounds good.
    I think Redd V. plays out of some Peavey steel amps sometimes and if you've heard his tone, well...
  3. openbar
    openbar Tele-Holic
    Boston
    Last night I had a chance to put a redline Bandit through the paces with the band. I had grabbed the amp cheap from an acquaintance. It really is like Peavey says: it's 95% there. By itself I wasn't blown away, but once I got it dialed in, and playing along with the band, it really shined.
    The only potential problem is that it is tapped-out, volume-wise. For the sound I like, with the pre-gain only on about 4, the master is at 10 to keep up with the band. Got a sweet sound though, and the only real difference from my tube amps seems to be slightly less sustain. Otherwise it really got the job done, I love it. Now if it were only a little more compact...
  4. repo1971
    repo1971 NEW MEMBER!
    Acworth, GA
    I know this is an old topic but thought I'd show off my 27 year old Rage 108. All original, near mint and rocks alot harder than it looks. Blue Stripes are the best of the SS Peavey IMO!
    ce24 likes this.
  5. slickoneuk
    slickoneuk TDPRI Member
    Yeovil
    The 108 was my first amp! I just bought a mint Red Stripe Bandit 112 tonight. Very excited
    JayFreddy likes this.
  6. Jbnaxx
    Jbnaxx Tele-Meister
    Arkansas
    I picked up a teal stripe Envoy a while back for 89.00 off eBay. It is in great shape and it even has the foot switch with it. It has surprisingly good reverb......and a lot of it.
  7. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Here's a history list off the Peavey forum: https://peavey.com/forum/viewtopic.php?f=19&t=14177
    "***History and Timeline of the Peavey Bandit***
    The Bandit
    (1980) The very first Bandit was only made for one year. As subsequent versions became available, the original Bandit came to be known as the "Gunsmoke Bandit" because the font used to silkscreen the logo on the front of the amp resembled the font used in the opening credits of the popular 60's television show, Gunsmoke. The Gunsmoke Bandit was made in Meridian Mississippi USA and had a power rating of 50 watts RMS. It came equipped from the factory with a 12" guitar speaker made for Peavey by Eminence.
    Solo Series Bandit (manual not available... Send me a message if you have one you can scan!)
    (1981-1983) The Solo Series Bandit soon followed the Gunsmoke Bandit and incorporated a variety of improvements, most notably a much improved sound. The Solo Series Bandit was made in Meridian MS USA and came equipped with Peavey's proprietary guitar speaker, the Scorpion.
    Solo Series Bandit 65
    (1983-1987) With the Solo Series Bandit 65, large improvements in tone compared to the previous version were again realized and the power rating was increased to 65 watts RMS. The Bandit 65 was made in Meridian MS USA and came equipped with Peavey's proprietary guitar speaker, the Scorpion.
    Solo Series Bandit 75
    (1987-1989) The Solo Series Bandit 75 saw the power increase by 10 watts to 75 watts RMS and a Bright Switch was added. The Bandit 75 was made in Meridian MS USA and came equipped with Peavey's proprietary guitar speaker, the Scorpion.
    Solo Series Bandit 112
    (1989-1995) The Solo Series Bandit 112 introduced many new features, the most notable being an increase in power to 80 watts RMS and a choice between Peavey's Scorpion speaker and Peavey's newly introduced Sheffield speaker. Many of the innovations that would later be branded as "Transtube" were included in the Solo Series Bandit 112, but the name "Transtube" had not been adopted yet. There have been several different versions of the Solo Series Bandit 112 but they all share the same manual and the same control layout. One of the more popular variations is known as the "Teal Stripe" or "Blue Stripe" Bandit due to a blue horizontal stripe below the control panel. The Solo Series Bandit 112 was made in Meridian MS USA.
    Transtube Series Bandit 112
    (1995-1999) The Transtube Series Bandit 112 formally introduced Peavey's proprietary "Transtube" technology that allows a solid state amplifier to perform more like a vacuum tube amplifier. Central to the Transtube concept is a patented "power brake" that allows the user to control the amount of power required for dynamic range compression from the power amp, from 100% all the way down to 10%, thus enabling the amplifier to acheive power amp compression without running at full volume. The Transtube Series Bandit 112 was made in Meridian MS USA and came stock with the Sheffield 1230 speaker. Notably, it was also the first Bandit to have an external speaker jack, allowing external speakers to be run instead of or in parallel with the internal speaker. Running into 8 ohms, power is still 80 watts RMS, but running into 4 ohms (the equivalent of using the internal 8 ohm speaker together with an 8 ohm extension speaker) the power is increased to 100 watts RMS. Due to the horizontal strip of chrome underneath the controls, this version is commonly referred to as the "Silver Stripe" Bandit, but due to the black color and square shape, it is sometimes called the "Blackbox" Bandit (not to be confused with "Blackface", which refers to Fender products and/or performances in the style of Al Jolson...)
    Transtube Series II Bandit 112 Made in USA
    (2000-2004) With the Transtube Series II, the metal corners and input jacks that had been standard on all Peavey Bandits up until this time were replaced by plastic corners and plastic jacks. Due to a color scheme incorporating a red stripe across the front of the amplifier, many people refer to the Transtube Series II Bandit as the "Redstripe Bandit". During this time Peavey attempted to adopt a new company logo, and moved away from their traditional "pointy" logo. The new logo came to be known as the "Block Logo". The Block Logo was only used for a limited period of time, and the Block Logo Redstripe Bandits represent the last Peavey Bandits to be made in the USA.
    Transtube Series II Bandit 112 Made in China
    (2004-2005) This amp is cosmetically nearly identical to the USA version, so it is also referred to as "Redstripe Bandit", but there are several differences between the US built Redstripes and the Chinese ones. First, the Chinese version says, "Designed in the USA" on the front, while the actual USA version says "Designed and Made in the USA". Second, the speaker in the Chinese version is either unlabelled, or is labelled "Blue Marvel", a Peavey code for speakers made outside of Peavey and then rebranded as Peavey. All of the USA Redstripe Bandits shipped from the factory with US made Sheffield 1230 speakers. Another obvious difference is that all Chinese Redstripe Bandits have the "pointy logo", while most - but not all - of the USA Redstripe Bandits shipped with Block Logos.
    Peavey Bandit with Transtube Technology
    (2006-current) The current version of the Bandit is made in China. It is the first Bandit to incorporate a "simulated output" for recording purposes. This simulated output runs independently of the amp's internal speaker, allowing silent recording. The simulated output can also be used instead of or in addition to a traditional microphone. In this version the spring reverb has been replaced by a digital reverb circuit, and the 10% to 100% T. Dynamics knob is replaced by a 3-way switch, allowing operation at 25%, 50%, and 100% power. Metal corners are reintroduced, but the footswitch is no longer included with the amp and must be purchased separately. Due to the new oval logo that resembles an eye, this model is sometimes referred to as the "Cyclops" Bandit."
    DADGAD likes this.
  8. DADGAD
    DADGAD Tele-Afflicted
    Earth
    Peavey Transtube amps are very nice to play. I use them with pedals. I gigged a Silver Stripe Envoy until it could not keep up with a loud band on stage. So, I moved up to a Red Stripe Studio Pro. All have been 100% reliable.
    My collection at one point...
    hrstrat57 likes this.
  9. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    Which Bandits have the "T-Dynamics" knob that the guy in the middle video above says is the key to getting a good grind from the clean channel?. Do all of the older ones have that control?. That is what I find confusing.
    Al
  10. William Pugh
    William Pugh TDPRI Member
    Quebec
    Starting from the silver stripe on, it seems to me. But then again, I've never had one, so...
    Let's let the others answer.
  11. Honest Charley
    Honest Charley Tele-Holic
    Sweden
