The best recipe for a raging 5e3?
Discussion in 'Glowing Bottle Tube Amp Forum' started by Muzzy, Dec 6, 2020.
  1. Muzzy
    Muzzy TDPRI Member
    There are 5e3's and then there's really good 5e3's that sound like they're on fire and about to explode. What's the secret recipe that make some of them sound like they're really pissed off? Certain transformers with certain coupling caps with certain speakers? I've built two 5e3's so far and experimented with a lot of different caps and speakers and both of them sound good but, they don't rage like some that I've heard unless I boost the crap out of them. I'm sure some of you guys here have built some exceptional sounding 5e3's. What components did you use?
  2. bblooz
    bblooz TDPRI Member
    Detroit area
    Any good build should sound right, but speaker selection is probably the biggest varying factor. I would say the cabinet construction can be a close second. (old pine vs. new vs. ply vs mdf, etc)
    SacDAve and El Tele Lobo like this.
  3. High Head Brad
    High Head Brad Tele-Meister
    Have u tried to jumper the channels?
    muscmp and VillainSean like this.
  4. dankilling
    dankilling Tele-Afflicted Silver Supporter
    Lehigh Valley, PA
    Raging as in Neil Young raging or raging as in early Eagles?
  5. Lowerleftcoast
    california
    IMO... there is a lot of variance between cool bias (90% to 100%PD)and 115+%PD.
    Also, a higher B+ seems to noticeably smooth out the 5E3. 350V vs 380V makes a difference.
    It is easy to lose signal gain when the volume and tone pots are less than 1M. Measure and correct the pots.
    OMMV.
    DADGAD, monkeybanana and Wally like this.
  6. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    maybe the OP can post a few examples...?
  7. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
    All of this. ^^^. Mine has more in the transformer department than spec that got me a lot of B+. You could also try different rectifier tubes as long as you don’t exceed the OT’s specified mA.
  8. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    12ax7 in v1? The speaker's a pretty big deal, too.
  9. Muzzy
    Muzzy TDPRI Member
    OP here. My amps sound good but, seem to be more polite than some I've heard. They are Boothill kits with ClassicTone transformers but, when I bought them I was sent the 40-18002 output transformers that are for a Deluxe reverb instead of the 40-18022 tweed deluxe transformer. When I asked Dave about it, He said he liked those better so, I went with them. Would that make much of a difference?
    moose likes this.
  10. Lowerleftcoast
    california
    Definitely a difference. The 5E3 likes the 8k primary. The 6k6 primary will make it more of a gentleman.
    DADGAD, Nickfl and jsnwhite619 like this.
  11. Muzzy
    Muzzy TDPRI Member
    Yeah, that's what I thought.
  12. Muzzy
    Muzzy TDPRI Member
    I ordered the proper OT from Mojotone. Will see if that makes a difference.
  13. dankilling
    Lehigh Valley, PA
    The Mojotone OT sounds great to my ears. I use them in my 5e3 builds. Classic tone sound good, but I’ve had some quality issues with them- the secondary winds are sometimes unbalanced so biasing ends up being a balancing act when you want to ride the edge of ‘safe’
    monkeybanana likes this.
  14. DADGAD
    DADGAD Friend of Leo's
    Earth
    Use the parts that Leo Fender had available back in the day and go from there. Carbon comp resistors, PIO caps, silver mica tone cap, American glasss, alnico speaker, solid hookup wire, chrome plated steel chassis, pine cabinet, etc.
    Wally likes this.
  15. Wally
    and hot power tubes. Imho, the circuit demands 100% of max plate dissipation. That is when the cleans are the liveliest and the overdrive is the best, ime/imho. The choice of tube specs is paramount in attaining whatever sound one wants coming out of the speaker. I serviced a vintage 5E3 once that had some really cold power tubes in it. I could not stand the sound, but it was just what the owner wanted. It sounded nothing like what I want a 5E3 to sound like.
    DADGAD likes this.
  16. Ess Eff
    Ess Eff Tele-Afflicted
    Earth
    I just tweak the tubes and speaker to my taste.
  17. Muzzy
    Muzzy TDPRI Member
    Thanks for all the info so far guys. My amps have carbon comps and silver mica tone caps. Both amps have RCA nos glass, pine cabinets, and reconed Jensen p12p's in them. Coupling caps are jupiter reds in one amp and mallory 150's in the other. I used cloth covered stranded wire in one and cloth covered solid wire in the other. Both have the deluxe reverb OT in them though. I'm hoping the Mojotone 5e3 OT makes the difference.
    Wally likes this.
  18. Wally
    one would be curious to know what the bias numbers are, ime.
  19. Jimy
    Jimy TDPRI Member
    California
    The output transformer is a key ingredient to the 5E3 sound. Those Deluxe Reverb OT's you're using will take you towards a cleaner, fuller sound... opposite of the "gnarliness" you seek.
    Higher plate voltages will make the amp louder, tighter, and punchier with less sag. Vintage amps running at vintage wall voltage should show something like 350V on the 6V6 plates. Check your voltages.
    Once you get those things sorted out, then you need to dial in the bias.
    Also, you're using three 16uf caps in the power rail, correct? Not 20uf or 22uf? More capacitance here makes the amp tighter and cleaner... again, the opposite of what you seek.
    Cantbreak100guy and Wally like this.
  20. Muzzy
    Muzzy TDPRI Member
    I'm not a tech and built these amps out of pandemic boredom. I recently bought a meter but, haven't had time to teach myself how to check the bias yet. They both run good and no red plating or excessive heat so, I figured I was good for now. I'm still learning.
