That un-numbered volume knob
Discussion in 'Telecaster Discussion Forum' started by Mr Perch, Feb 17, 2014.
  1. Mr Perch
    Mr Perch Tele-Afflicted
    los angeles
    Do any of you fellows have any tricks for when you're on the gig, you're about to launch into a tune, and you want to make sure that you have the appropriate volume level on your Tele for the rhythm guitar part you are about to play? Once upon a time I played Gibsons, and I relied on the numerals that adorn the volume knob. Does anyone have a special method, or do you just use The Force?
  2. stnmtthw
    stnmtthw Friend of Leo's
    New Mexico
    I use the set screw on the volume knob as an indicator.
  3. SixShooter
    SixShooter Friend of Leo's
    Cincinnati
  4. sax4blues
    sax4blues Friend of Leo's
    Colorado Springs, CO
    That's it, simple.
  5. Davo17
    Davo17 Friend of Leo's
    Southern California
    I like to set the set screws so they are pointing straight up when set for rhythm (at 75% or so), and all the way forward (towards the selector switch when they are full up.
    I do the same for the tone knob. Its nothing fancy but it is a visual indicator, usually though I just listen and adjust on the fly, I dont like to have to squint at anything while Im playing.
  6. FredDairy
    FredDairy Friend of Leo's
    Chicagoland
    So when you played Gibson were your amps always the same? Seriously one flick of the volume knob on an amp or switching to a different amp makes the numbers on the guitar knobs pointless.
    You need to know your own personal attack with your picking hand and adjust volume knob accordingly.
  7. rockabilly96
    rockabilly96 Tele-Meister
    My trick is to turn the guitar volume all the way up before the song, and then roll it back quarter of the way before I start (assuming I will be starting of with rhythm). But for the most part, I am regularly adjusting my volume, especially if my band mates adjust their volume
  8. MickM
    MickM Friend of Leo's Platinum Supporter
    A steel guitar engagment.
    I do the same thing. You can also get a set screw that's just long enough to stick out 1/16" or so. Or.....Get a 3/16-1/4" bit and slightly countersink the set screw hole so you can feel where it's at.
  9. sonny wolf
    sonny wolf Friend of Leo's
    austin texas
    I just use my ear and determine if the volume and tone level suits the musical piece I am about to play.
  10. Davo17
    Southern California
    Thats a great idea for low light stages etc.
  11. PCollen
    PCollen Friend of Leo's Silver Supporter
    Man of the World
    I just strum a chord, listen, and adjust if necessary.
  12. musicalmartin
    musicalmartin Poster Extraordinaire
    Norfolk UK
    I use my ears .You tend to just know the right position but also attack on the strings will suffice for say a sharp well defined lead break and then, flicking the pickup switch ,with less force a rhythm beat.
  13. waparker4
    Philadelphia, PA
    +1
  14. Mr Perch
    los angeles
    The knob on my Squire CVC Vintage Blonde doesn't have a set screw.
    That's basically what I have been doing, although I need to make it more conscious and scientific. I constantly adjust my volume when playing, but that first chord is sort of important, and I can't do any adjusting until I hear everyone else. And since I play in an instrumental trio, it's very noticeable if I get it wrong -- there's no other chordal instrument to take up the slack.
  15. orangeblossom
    orangeblossom Friend of Leo's Silver Supporter
    Renfrew county, Canada.
    Been using a volume pedal for years. Great for swells and steel licks.
  16. SPUDCASTER
    Grangeville, Idaho
    ^^This^^
    Works every time!:D
  17. zeke54
    zeke54 Tele-Holic Silver Supporter
    central calif.
    Set screw , been using that method for 40 years . If your Tele knob has no set screw , get a knob that does . Z54
  18. pmcgee
    pmcgee Tele-Meister
    You will get used to it after a while. No need to look down or dial it in at a number...or line it up with the moon or whatever....after a while it just becomes something you do without really thinking about it. Backing off the volume on the guitar will change the tone .. Volume usually full up on the guitar with a foot volume pedal. You can change that very fast. But that is just me.. Wonderful thing these Tele"s.. Enjoy...Phil
  19. robotguitar
    robotguitar Tele-Holic
    visalia, CA
    If your lucky enough to have a sound person, then volume is all the way up for me. If not and there's no pa, I always start all the way up and then listen. I have a few things to boost, but mainly the volume knob and a lighter touch to decrease the volume. In these situations it's usually about doing a good sound check and getting the right levels. My volume knob 100% 95% of the time.
  20. Twang Man
    Twang Man Tele-Holic
    United Kingdom
    Set full up, number ten, loud as it'll go... then loosen the grub screw and remove knob. Never worry about it again, it'll be fine.
    If it's too loud then you too old...
