tex mex help.....
Discussion in 'Stratocaster Discussion Forum' started by TheOutlaw, Jan 14, 2021.
  1. TheOutlaw
    TheOutlaw Tele-Meister
    United States
    I bought a used MIM Strat a few months ago because the price was right and I had enough spare parts that I thought i could make it what I wanted. First step was ditching hotrails and I already had a tex mex set i took in trade forever ago so it was a no brainer... or atleast I thought.
    I installed them reusing the harness that came with guitar since they looked like 250k cts and ised a tone cap that was from a Squier sss i had laying around. I have loved strats for years but I never got the whole ice pick thing people complained about until putting these pickups in. It was horrible so I took the pickups out and push the pool pieces back in to flatten the ark a little bit. Put it back together and it was a little better but still nasty to play to the point where I would cringe when picking single high notes. I played with pick up Heights but that isn't doing enough.
    I think changing tone caps is pretty much my last and best option. I have both 0.22 and 0.47 orange Drop caps as well as another set of pots and why her in case I screw up. Currently the turn knob controls bridge but sounds not so good to me when rolled back.
    I have done a lot of setup work but not really much Electronics work on guitars but from what I understand switching to the 0.22 orange drop cap should tame the highs a little bit correct?
    Is there anything else I might try to help actually like this pick up?
    I haven't really had time to even try to dial in the neck or middle pickup height I kind of like those it is just the bridge pickup that I absolutely hate and usually that is the pick up I go for on most strats
  2. viking
    viking Friend of Leo's
    Denmark
    Tex Mex for Tele , is a cheap-ish set of Fender pu´s , some have a different opinion than me , and thats ok !
    I like them , have a few sets , and just install both pickups at 2 mm clearance treble side 2.2 mm bass side , strings pressed down at last fret.
    Works for me !
  3. Racer5
    Racer5 Tele-Afflicted
    San Antonio, TX
    I'm sitting here right now with a JV strat with tex mexes
    couple things I noticed that help to smooth them out
    - LOW pickup height. definitely lower than I'd normally think to set a strat
    on this note, the bridge pickup sounds better when it's set flat across, no rise on the treble side
    - the JV comes stock with the tone control set to the bridge pickup--this is a fantastic mod for any strat and really makes the tex mex bridge pickup more useful. even taking it down to 8 or 9 gets it round enough to be more useful
    Peegoo likes this.
  4. DougM
    DougM Poster Extraordinaire
    Honolulu, HI
    I'm pretty sure you have it backwards- A higher value cap will tame the highs more than a lower value one. I've been playing Strats my whole life, and so I like their bright sound, and I haven't played any with Tex Mex's in a while, but, from what I can recall, they were one of the brightest Strat pickups I've ever heard (too bright for my taste, even though I like glassy vintage type pickups more than hot, overwound ones). That being said, @Racer5 is correct, lowering the pickups will warm them up, and higher will make them brighter. And, as to his comment about having the treble side of a pickup higher than the bass side, I don't know why Fender does that at the factory on their Strats. I've never liked it, and I always set the pickups on my Strats to have both sides the same height.
    schmee and Racer5 like this.
  5. Tarkus60
    Tarkus60 Tele-Meister
    Salem In
    I installed a set in my 92 mim, my friend has a set in a strat. They are fine in the strat I hated mine in the tele. replaced with vintage 52's ah much better.
  6. DougM
    Honolulu, HI
    I've just been watching a YouTube channel called Direct Recording Guitar, where he samples different tones on several multi-effects pedals, and on the ones that he sets up for a bluesy John Mayer/SRV type Strat sound, he's using his Strat with Tex Mex pickups, and they sound really good on the Boss GT1, and the Zoom G1 Four. I'm seriously considering trying some Tex Mex pickups in one of my Strats now, 'cause at $100, they're less expensive than just about any other good Fender set for Strats.
  7. richiek65
    richiek65 Friend of Leo's
    Sydney NSW Australia
    Mine are in a MIM classic player and are way warmer than the CS69s that came from the factory. I am super happy with them, i do have the tone control wired to the bridge but even if i don't use it, the bridge pick up is not what I would call ice picky. Those CS69s were parting peoples hair at 20 paces
    FortyEight likes this.
  8. viking
    Denmark
    Once again , I managed to mix up Tele and Strat , sorry.
  9. 3-Chord-Genius
    Winchester, VA
    Not sure about the strat Tex-Mex set, but I have the telecaster set and they're my favorite of all telecaster pickups I've tried.
  10. Racer5
    San Antonio, TX
    Right? It's one of those ancient rules that may be true for some pickups. I just got this tex mex strat and have been dialing in the pickups, and right now they are set pretty much flat and are sounding more balanced. What's the point of all that factory polepiece staggering if you're just going to muck it up with the pickup angle?
    DougM likes this.
  11. FortyEight
    FortyEight Tele-Afflicted
    Southeastern Wisconsin
    Can you push the pole pieces to flatten them? I've seen guys do this. I THINK they are kind of waxed in there and can move once budged. At least that's what I've seen but I'm not sure if that's with the tex mex pups or not. I'm assuming the tex mex pups don't have a bar magnet on the bottom, right? The pole pieces are the magnets?
    Racer5 likes this.
  12. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    Just jump a wire as shown below. This will give you tone control to the bridge pickup and take the ice pick. I do this on all my strats.
  13. TheOutlaw
    United States
    Like I said in the first post turn control is already connected to the bridge pickup and I already pushed the pole pieces down a little so they are just between being flat across and matching the radius of the fretboard. I haven't gotten around to messing with the wiring again yet.
  14. schmee
    schmee Doctor of Teleocity
    I have and prefer Tex Mex in all my Strats and dont have that issue. Not sure what to say. you need tone control on the bridge pickup? On the other two I'm usually wide open on tone though.
    Are you sure your wiring is correct?
  15. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    You didn't mention the amp you're playing through. Have you tried tweaking the tone controls on the amp?
    The sound of an electric guitar is dependent on the guitar and the amp.
  16. TheOutlaw
    United States
    With the tone wide open it is almost painful to listen to but as I roll off the tone knob it kills some of the highs but it also makes it sound like crap. This carries over no matter which amp I use so far I've had it plugged into a 60-watt Fender supersonic 5 watt Blackstar, a 15 watt bassbreaker, and a fender musicmaster bass amp. The wiring seems to be correct all of the knobs function and I'm happy with the neck and middle pickup. I'm still hoping it is just the Cheapo generic tone cap I pulled out of an old Squier pickguard. It was a tiny green chicklet looking thing. I have brand new orange drops I just haven't felt like taking it all back apart for the 50th time in 2 weeks LOL. I'm really hoping to get back to it soon because I'm actually starting to bond with the feel of the guitar but I'm also knee deep in about 300 other projects at the moment.
    Besides the 70 Hour Work Week I've been busy trying to gather supplies to start a tele build and I have been chomping at the bit trying to finish a workbench that I started a few years ago.
  17. Fenderdad1950
    Fenderdad1950 Tele-Afflicted
    Albuquerque
    Ah Tex Mex, years with them, served me well. Sidestepped over to Texas Specials. Muy Caliente ......oh yeah :cool:
  18. TheOutlaw
    United States
    Is one not just a more economical version of the other? I was under the impression it was kind of like mim Strat vs. USA Strat?
  19. Racer5
    San Antonio, TX
    I came here to update this thread because I just did this -- used a fat feeler gauge and some thumb pressure and completely flattened all those peaky polepieces.
    The result is noticeable, combined with the low height I'm finally getting these to sound just how I want. Happy to avoid another $150+ replacement set.
    They are completely fine to push back because the bobbins are plastic. Requires very minimal pressure.
    This is where I have them sitting now--
    mkdaws32 likes this.
  20. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    With all the pole pieces flattened and a 7.25 to 10 inch fret board radius I feel the D string is suffering. I prefer a modern stagger with the those lower radii.
