Terminal strips dimensions?
Discussion in 'Shock Brother's DIY Amps' started by JohnnyCrash, Jul 12, 2009.
  1. JohnnyCrash
    JohnnyCrash Doctor of Teleocity Gold Supporter
    Fullerton, CA
    I'm trying to draw a layout for my dual 6L6 two channel high gain build.
    I'm using a few 8 lug terminal strips and need to know their dimensions so I can draw this thing up to scale and make sure I can get everything fitting in this chassis right.
    1. How long are the 8 lug terminal strips?
    2. How long are the 3 lug terminal strips?
  2. muchxs
    muchxs Doctor of Teleocity
    New England
    Straight from Chez Junque:
    I don't have 8 lugs close at hand but I have lots of 5s and some 3s.
    You can see an 8 would be 3" OAL with last lug to last lug at 2 5/8".
    3 lug is 1 1/8" OAL.
    The lugs are spaced 3/8" C-C. Bear in mind that if you use this style strip the two mounting lugs go straight to ground, you may lose 2 lugs per strip in some apps.
  3. JohnnyCrash
    Fullerton, CA
    How did I know YOU'D be the dude to know?
    Thank you, I don't want to wait for parts to situate everything - thank goodness for graphics software :)
