Tension Free Necks
Discussion in 'Tele Home Depot' started by rbarr110, Dec 2, 2014.
  1. KeithJ
    KeithJ Tele-Meister
    Reindeer
    I hate it when companies make up words that sounds scientific like "Sustainiun". They have also erroneously combined the words "in stock" to create "instock". And how can there be 5 generations of luthiers with only 50 years of experience?
  2. MickM
    MickM Friend of Leo's Platinum Supporter
    A steel guitar engagment.
    I don't like to squash something that goes against the flow without seeing/hearing some kind of comparison. I figured that if this approach made a noticeable improvement that the sellers would have a you tube video of a stock fender being played and then, the same fender with the new neck with the player doing the same tune/licks at identical settings. We viewers/listeners would then be able to decide with at least a small amount of info, whether or not it would be a worthwhile mod.
    I couldn't find any videos of comparisons, anybody find one?
  3. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    So then the wood adds nothing to the equation, including any tone benefit. It's just there to hold on to.
  4. guitarbuilder
    Your run of the mill neck....The strings are under tension, the top of the neck is under compression, the bottom side of the neck is under tension. The truss rod counteracts the compression with its own compression and tension forces. When combined, aren't the neck resulting forces at equilibrium when the rod is then adjusted so the neck is flat against string tension? Somebody please do a vector analysis of this....
  5. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    A force diagram would show that the compression forces in line with the length of the neck do not effect relief, relief is all about the tangential "sheer" forces - which are applied as significant "compressive" forces just slightly off center enough to create a small tangential force: Leo's simple design to contour the truss slot to maximize the tangential force in just the right direction from the rod is pure genius.
    If someone came up with a truss design that minimized compressive forces - it would likely work fine, but as Nick mentioned, wood handles compression better than most materials: I think any discussion about tone should really be about the composite of materials in a neck design as tone is a lot more about dynamic forces in vibration and not at all about where static forces are applied.
    If someone were to talk about "tone" as an effect of static forces - I would think they do not understand the physics involved in a musical instrument. Unless they mean the pitch of a note and use the word tone....
  6. slinger
    slinger Friend of Leo's
    wild west
    Who cares if its under tension or not.. ..how does this make for a better playing guitar?
  7. Greg M
    Greg M Tele-Holic
    Virginia
    Bingo.
    Now let's talk about the possibility of a cake-free Twinkie.
  8. jkingma
    Admin Post
    Twinkies are already cake free.
    It may look like cake, but it ain't cake.
    :D
  9. Mojotron
    Seattle
    it's all about the [​IMG]
  10. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    I've made a bunch of necks using static (non-adjustable) steel rods fitted tightly and epoxied in. In a tap test these beat hell out of the anything with an adjustable rod in them. They ring nearly like a regular piece of wood instead of that 'thunk' you can get after installing an adjustable rod....but do they sound 'better' in a guitar? I doubt it.
    Just to be safe though I'm going to claim they do and tell everyone I use cold-rolled, cryogenically treated, depleted uranium I call 'Unobsustainium™' to make mine.
  11. guitarbuilder
    Suzy Q's were an excellent treat back in the day when the ingredients were a bit more wholesome...LOL. This stuff doesn't taste the same anymore.
  12. Mojotron
    Seattle
    They tasted a lot better back in the day when I was blissfully ignorant to the notion that the ingredients were aiding my demise - given my age - if I ate one now people would assume it was a suicide attempt... :lol:
  13. orangedrop
    orangedrop Friend of Leo's
    New York
    could it be possible they tasted better "Back In The Day" because we all had the munchies?:D
  14. TRexF16
    Tucson
    Pizza was WAY better back then too.
  15. jkingma
    Admin Post
    Greasey pizza and Carling Black Label brings back a lot of memories.
  16. guitarbuilder
    Hey Mabel....Black Label..... and don't forget 10 cent wings....:)
