Phaedros
Well... after completing my Junior build I´m contemplating on building another double cut - this time of my own design.
There is one particular problem I`m running into though. I don´t want to use a pickguard and it´ll have two pickups, so tenon length/ construction is an issue.
I´d love to go down the same route as I did on my junior but that would mean I could have a max tenon length of approximately 2" (s. below) - this would get me into´61 SG short tenon dimensions although my body is a good bit thicker than the spiky one´s.
The other solution would be to extend the tenon below the top I´d like to apply. That would introduce a whole different lot of problems though because I would either have to joint the neck before glueing the top or alter the tenon shape in a way that I can slide the neck under the top. Would dowels be an option?
I don´t want to alter the body shape to allow for a larger glueing area...
Any ideas?
Any ideas?
