Template Questions
Discussion in 'Tele Home Depot' started by aaronftnm, Jan 9, 2009.
  1. aaronftnm
    aaronftnm TDPRI Member
    Zoo Atlanta, GA
    Just curious how obsessive you guys get about your templates. Im about to go to my grandfathers house and use his bandsaw to make neck and body templates, but i am not the best with the bandsaw. I assume that i need to pay the most attention to the heel of the neck, and the neck pocket, but what about the rest of the template. How forgiving are the pilot bearings on a template bit. Will it show every small bump?
  2. Buckocaster51
    Iowa USA
    Admin Post
    yup
  3. LocustPlague
    LocustPlague Tele-Holic
    You should saw a bit on the outside of the lines. Sand the templates down to the line using spindle sanders.
  4. aaronftnm
    Zoo Atlanta, GA
    I like the spindle sanding idea pretty good, but i dont know if i have access to one or not. Would a drill press spin fast enough to use some sort of attatchment?
  5. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    They do make drum sanders that go in drill presses. For something like this they'll work fine.
    Keep in mind that spindle sanders work best on the insides of curves, and flat sanders like a belt or disc sander are for the outsides of curves.
  6. Shepherd
    Shepherd Friend of Leo's
    Maple Ridge, Canada
    If you have a drill press that would be perfect. You can get these from Grizzly or Harbour Freight.
  7. Vizcaster
    Glen Head, NY
    Actually, a drill press would have to be set to a relatively slow speed to be useful for a spindle sander. My father's DeWalt radial arm saw actually has an attachment for a spindle sander - ridiculously fast for anything except burning wood and tearing paper.
    I took a nozzle for the shop vac and screwed it to a board with a circle cut in it just big enough for the spindle. The nozzle aims behind the spindle sander. Clamp the board to the dril press. Works beautifully.
  8. WisconsinStrings
    WisconsinStrings Tele-Afflicted
    Arcadia, Wisconsin
    These work really well!
  9. aaronftnm
    Zoo Atlanta, GA
    I actually just called in a favor with my cousin who owns a cabinet making shop, and i sent him over a cad file of what i needed, and he got it made up on the cnc router. It took like ten minutes tops, and looks better than my sketch bandsaw operation.
  10. gitlvr
    gitlvr Friend of Leo's
    Northern Va.
    When I build templates, I use a jig saw close to the line, then follow up with one of these:
    Yeah, I know, not very high tech, but I'm power tool challenged and if you know how to use it and take your time, it'll work well.
  11. TELE_BLUES
    TELE_BLUES Tele-Afflicted
    ROCKCHESTER,NEW YORK
    Any time spent on making the templates as close to perfect as possible is time well spent.
  12. andrewb
    andrewb Tele-Meister
    sydney
    fixed
    but.. theres nothing like spending some quality time learning how to use your files :D
  13. braderrick
    braderrick Tele-Afflicted
    Kentucky
    ? I think he was saying to just get close to the lines (outside the lines) with a saw and then use files or a spindle sander to more accurately go around the lines.
  14. LocustPlague
    Yeah....you really should go on the outside edge of the lines with the saw so you cut the waste. If you cut inside the lines, you won't have any more waste to clean up with files/sanding.
  15. Vizcaster
    Glen Head, NY
    Santa left one under my tree after one of you guys suggested it here. I'm surprised no one else makes a combination spindle sander that's also an edge-belt sander (and even the single-purpose oscillating spindlesanders are more expensive). The whole 4 x 24" belt oscillates up and down and is nice for the convex areas. Turns out the spindles are all 4-1/2" (a spec that's not posted anywhere by Ridgid or Home Depot) and the sizes are easily available at my favorite sandpaper catalog: http://www.woodworkingshop.com/cgi-...EVES - 4.5" LENGTH&qryType=GRPSG&group=SLEEVE Can't wait to start playing with it for real.
