Tell me about my tube tester
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, Apr 13, 2021.
  1. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    It's a "Dial Junior" made by Custombuilt in San Francisco.
    Bought it for twenty bucks from a guy outside a bar on a Saturday afternoon about five years ago. It works very well so far, I've tested hundreds of tubes, and only one bad tube has crept through.
    I do plan to change the big cap and all the carbon comp resistors.
    20210412_223323.jpg 20210412_223346.jpg 20210413_142025.jpg 20210412_223323.jpg 20210413_142034.jpg 20210413_142020.jpg
  2. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    I salute the person who wired this up...
  3. Preacher
    Preacher Friend of Leo's
    Big D
    I got anxiety just from looking at that.
  4. archetype
    archetype Fiend of Leo's
    Williamsville NY
    I've never heard of that company. It will sort out the obviously bad tubes and let you move the good ones to an amp for real-world testing. I see a can of Deoxit in your future.
  5. Dacious
    Dacious Poster Extraordinaire
    Godzone
    It can certainly pick tubes with shorted elements but I wouldn't totally trust it's assessment of tubes as good or bad.
    A tube that tests less than good or green could still be serviceable.
  6. ArcticWhite
    Portland Oregon
    Already have it.
    archetype likes this.
  7. Engine Swap
    Engine Swap Tele-Afflicted
    Chicago
    You'll need another...
    Greg70, archetype and Dan German like this.
  8. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    I used to build card cages for a mil-spec data recorder. 714 wire connections in each cage. That looks more challenging.
  9. LudwigvonBirk
    LudwigvonBirk Tele-Holic
    Madison
    For at least 150 years, most of the product from the 300-block of Eddy Street in SF has been somewhat enticing, and simultaneously suspect wrt to safety.
  10. Zootallures
    Zootallures TDPRI Member
    Oregon
    Be careful using too much deoxit on tube testers. It can swell the phenolic wafers on the switches and cause problems. If you use it on the switches use a q-tip and only get it on the parts that are making contact. I’ve seen people suggest contact cleaner or 99% alcohol
    ArcticWhite and archetype like this.
  11. radiocaster
    europe
    Interesting. I think it had one of those rolling things with the chart for the settings, but I think that's in the manual as well.
    So it's all solid-state? The complicated part might be to calibrate it.
    ArcticWhite likes this.
  12. ArcticWhite
    Portland Oregon
    Luckily, it came with a stack of printed settings for just about every tube made before the mid-sixties, as well as the two page instruction manual.
  13. Zootallures
    Oregon
    That’s a really cool tube tester! Did the manual come with a schematic and instructions on how to calibrate it? It looks like there’s two potentiometers in the middle behind the meter that are probably for calibrating.
  14. robrob
    United States
    Robert Hull has a tube tester facebook group if you need any help with it.
