joebloggs13
Two turntables and a microphone....
....Kidding aside...I love them both...and 335s, and Strats. The Tele is the only type of which I own two tho....so there is that.
Lotsa people think Funk #49 is LP.Pagey made the switch. Most people still think that Led Zep I and Stairway’s solo were done on a LP.
Hi.
I firmly believe (i.e. it’s actually just an opinion, regardless of how strong it is held) that a typical single coil Tele and a typical humbucker equipped LP can sound near identical. Especially recorded.
There’s a lot of factors going on though, like amp types, pedals, settings on guitar and the aforementioned, musical style, playing technique, recording techniques, etc.
So, it’s not some kind of absolute thing.
I bet someone could set things (gear, in other words) up so that swapping between an LP and a Tele in one situation would yield no discernible difference in the results (discernible in the test of telling which slight variation is which when blindfolded), and so that in another setup / situation they’d always sound clearly different.
And I bet you could play that game with pretty much any other pairing of electric guitars too.
Having said all that, I’ve also met people with far more ability than me to hear tonal differences. So, there’s another factor to throw in the mix. Not to mention, literally, 'the mix.'
And on top of all that, I do still find that an LP and a Tele really compliment each other when double tracked and panned hard each way. I find there’s *usually* enough tonal difference that they stand apart slightly, but also sound really good together, creating a ‘more than the sum of their parts’ kind of whole. But, I also find that going back later, I can’t tell which one I panned left and which one I panned right…
Pax/
Dean
Ha ha ha! I've seen several Gibsons with that classic break below the nut. My first Tele fell from a stand once, and the tuner that was attached on the headstock smashed into a dozen pieces. The Tele was still in tune.
Uh oh.
Les Paul > T type with Floyd.
My opinion, our course!
I get what if I owned a Les Paul moments every once in a while but then I play my Gretsch Duo Jet with TV Jones T-armonds and realize I have that sound and scale length pretty much already. When I want the Duane Allman, Neal Schon or Jimmy Page sound the Duo Jet fills that niche well for me.
You often hear that a good Les Paul is like a Tele on Steroids. Lets have a battle and see if that's the case.
Got it covered, Bro.Don't understand why people compare Srats, Teles, Les Paul's... or try to make one sound like the other. We all need one of each.
The instruments scale length fundamentally shapes the sound of an instrument.
Any time I pick up a tele it takes me a minute to adjust to the additional hi end information. I'm sure some find the difference insignificant, but I hear it clearly.
People say Telecasters are ugly but then I look at the LP. I just don't get it. We can't all like the same thing etc but I just don't get the appeal at all.
