Telecaster three way switch alteration?
Discussion in 'Tele-Technical' started by 52BIGSBY, Mar 29, 2020.
  1. 52BIGSBY
    52BIGSBY Tele-Meister
    Emsworth UK
    Hello.
    My current Telecaster has a three way switch that I have modified very simply by removing it, using two pairs of nose end pliers, and the bending the end downwards. This results in the selector being positioned more "out of the way" of my rather active strumming hand.
    Although mainly working I was thinking that a lower flat small knob that moved laterally would be a better solution.
    Does anyone know if there is a solution to this other than changing my playing style?
    I have thought of buying a Gibson Junior, but much prefer the Telecaster single coil tone and clarity, and think that a Gibson equipped P90 guitar might be a bit dark for me. I also think that reversing the control panel would result in me accidentally turning down the tone when "away with it", (the same problem reversed).
    Thank you for your suggestions.
    Richard.
  2. 8trackmind
    8trackmind Tele-Afflicted
    Dark side of the moon
    Strat switch tip solves 90% of the problem.
    TimT likes this.
  3. 52BIGSBY
    Emsworth UK
    Thanks for the reply, however it is still in the line of fire of the strumming hand, albeit slightly lower.
    I have had a further idea. I never use the tone control, so why not remove it, reverse the panel part, change the wiring so that the volume pot works clockwise, thus having clear space for when things get lively at the strumming end.....
    The eventual result of this is that if effectual, it would be good to have it on a quality or even historic instrument.
    I guess any modification is reversible if the original parts are retained.
    I am sure the purists are cringing!
    Richard.
  4. warrent
    warrent Friend of Leo's
    toronto
