Telecaster Neck And Neck Pocket Dimensions
  • Thread starter Telecastermusic
Telecastermusic
northumberland, UK
Hi, I have a telecaster body and neck. The neck is a perfect fit in the neck pocket, however, the neck appears too thick and the fretboard stands about thirteen mm above the body. Can anyone tell me the correct depth of the neck at the heel and how high the fretboard should be above the body. Also, what is the best way to reduce the thickness of the neck at the heel?
thanks, Ian
guitarbuilder
Ontario County
Here's my take on it all:
Typical numbers are the neck pocket is 5/8 deep. A neck is 1" thick. The neck sticks up 3/8". You can rout the neck pocket down. You can remove material ( maybe , depending on truss rod anchor) off the bottom the neck. You could put some material under the bridge to elevate it. Some people would recommend putting a shim at the front of the neck pocket at an angle, making the neck tilt up... which I think is bogus.
My logic is this. Which has more value and is more accurate? If it is a 30 dollar neck from China and the neck is too thick, I'd take it off the bottom of the neck. If the error is in the body, I'd fix the body. That is assuming your saddles won't go up that 1/8" or so to give you the correct action you like.
To remove the material from the neck, I'd scribe a line around it with a combination square and awl, and probably sand it on a belt sander, ensuring I don't go past the scribed line.
If I'm removing material from the pocket, I'd get a router with a large base, and use a short pattern bit to ride inside the pocket. It can also be done with some chiseling and router planing ( both hand tools) too.
Captain Nutslot
Rochester, NY
so the neck pocket is just about 5/8"
Personally, I would shape a brass plate (about an 1/8" thick )or something exactly the shape of the bottom of the ashtray bridge and unite them somehow.
There's plenty to consider though, as guitarbuilder said.
RickyRicardo
Calgary, Alberta
Didn't see it beside the pic. Guitarbuilder has the answer. If it were me I'd do the neck pocket but I have the tools to do that. Don't know if the OP does.
LeftFinger
The Land of Plenty
If it were me I would swipe the ole lady's lipstick and coat either the heel or the pocket ,assemble the neck and body , then take it apart and see where the color transference occurs.
Tervo
Finland
Me too. Considering You have a finished neck and an unfinished body, it would be much cleaner to remove those few millimeters from the neck pocket than the neck.
RogerC
Oklamerica
Not sure how that would help his situation o_O
guitarbuilder
Ontario County
The color transfer shows you where it's being held apart.Maybe I'm not understanding the problem but if 2 pcs won't fit together I like to see why.
Are you referring to the other threa
I could be wrong but are you are referring to yesterday's neck fitting thread?
http://www.tdpri.com/threads/les-paul-junior-ish-build-kit.609865/#post-6857558
If so, this thread has a different problem.
RogerC
Oklamerica
