Telecaster Deluxe Template
Discussion in 'Tele Home Depot' started by dawnofzion, Jan 12, 2009.
  1. dawnofzion
    dawnofzion TDPRI Member
    Lewisville, Texas
    Does anyone happen to have a Telecaster Deluxe template? I am going to start a new project and I am in need of one. Thanks.
  2. Nick JD
    Queensland, Australia
    I don't, but it wouldn't be hard to make from Terry's PDF file. It's the same body as a normal Telecaster (maybe with the weird 70s bits if you want to be accurate) but with a Strat neck pocket.
    The pickup routes template wouldn't be too hard to make depending on whether you need the bigger wide-range HB holes that are the same depth as the neck pocket. There's a lot of pickguard real estate to hide behind with the routes for wires and pups.
  3. scubadoo
    scubadoo Tele-Afflicted
    Bristol, UK
    I made one for a '72 Custom type build using the PDF's on the Fender website and fitting it to either Ed Hawley's or Terry Down's CAD file. Then i just drew around the pots to get the control cavity and switch cavity. I also used it to make a template for routing a pickguard. Not hard to do at all if you have the right software. If you're not a CAD user, just resize the PDF using a known dimension and print it out 1:1. You can then use that to draw on to make a template.
  4. dawnofzion
    Lewisville, Texas
    I am an architect, so I am a CAD user. Which files are you talking about that you used? Could you send me a link or something? Thanks.
  5. scubadoo
    Bristol, UK
    That's the one. I've made three from it and they worked out great.
  6. dawnofzion
    Lewisville, Texas
    I was told that the telecaster deluxe body is a little larger than a standard telecaster. If this is true I may need someone that has one to trace around the body and the routes.
  7. scubadoo
    Bristol, UK
    Not sure but seems unlikely to me, that would mean changing all the CNC about at the factory but I'm sure there are those here that can answer that.
