Guitar Quackery
That's the idea.I appreciate your insights and opinion. I agree on good conversations.
It is definitely true that people bring guitars to repair shops, when there's a problem or something to be repaired. I have a certain percentage of customers that bring brand new guitars to ask me if they should keep or return/exchange. Those are typically customers whose guitars I've worked on in the past.As a repair technician, you’re definitely going to see all the problems... The flip side is you don’t see the ones that never have a problem.
Regarding the Acoustasonics that customers brought in, they basically just wanted setups, then we discovered other issues.
In one of these two cases a replacement neck was sent and in the other case there was a refund. In both cases I was required to scrap the guitars (or just the neck, in the first case).
But I also see quite a few guitars without serious problems. Sometimes guitars just need a good cleaning, fret dress, restring and setup.
But to your point, that repair techs will definitely see a lot of problems, we also develop a mental picture about which guitars have the most problems. A lot of techs agree that Martin guitars are the leader in that domain: soundboard cracks, lifted bridges, overset or underset necks, binding falling off, etc...
With regards to the Acoustasonics that ended up in two of my videos, I guess I just had bad luck with the ones that were brought to me to work on, as it was a relatively high percentage of Acoustasonics that I saw (two in total) that had to be scrapped. To be fair, I think that was just the element of luck.
But I am still curious to know, how will they age?
We'll see.
