Tele V Strat
Discussion in 'Telecaster Discussion Forum' started by vishnu, Apr 29, 2019.
  1. vishnu
    vishnu Tele-Meister
    scotland
    I'm new to the Strat scene guys and was a wonderin' if i could expect there to be some difference in acoustic volume ( no amp) between the two guitars..... i guess the difference in body shape has to be taken into account but the difference in volume is quite marked, is this par for the course,the Strat being quite a bit quieter/polite ?
    Thanks guys
  2. brookdalebill
    Austin, Tx
    If the Strat has a traditional tremelo assembly, it’s acoustic sound will have a slight reverb effect.
    It’s caused by the tremelo springs.
    The unplugged volume, with similar set ups should be roughly the same.
    SolidSteak likes this.
  3. SolidSteak
    SolidSteak Friend of Leo's
    They both sound pretty quiet when they're not plugged in. Great bedroom volume :)
    joealso likes this.
  4. Nick Fanis
    Athens-GREECE
    Yes the strat will sound "quieter" accoustically
    Tonetele likes this.
  5. PlainAllman
    PlainAllman Tele-Holic
    Van Zandt Co, Texas
    Unless the strat belongs to Spinal Tap. Then it goes to 11 even unplugged.
    hemingway and Volktar like this.
  6. vishnu
    vishnu Tele-Meister
    scotland
    thanks guys :)
  7. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Strat is noisier unplugged with the springs and the plastic pickguard. Source: have both.
  8. ClashCityTele
    ClashCityTele Tele-Holic
    Washington, UK
    Nigel Tufnel: (holding up a guitar) The sustain, listen to it.
    Marty DiBergi: I don't hear anything.
    Nigel Tufnel: Well you would though, if it were playing.
    SolidSteak, PlainAllman and warrent like this.
  9. VillainSean
    VillainSean Tele-Meister
    Seattle, WA
    Strats are usually "quieter" as they don't resonate as much as tele, with it's fixed bridge.
    Zepfan and Tonetele like this.
  10. perttime
    perttime Tele-Afflicted
    Finland
    The tele bridge plate might increase acoustic volume. At least my tele(ish) guitar is louder unplugged than my hardtail strat. The chunky neck of the tele(ish) guitar might affect things too, though.
  11. Route67
    Route67 Tele-Meister
    The Tele bridge plate acts like a mechanical speaker by amplifying the sound of the strings from vibrations transmitted through the saddles.
    A while back when I was deciding between Strats and Teles for quiet unamplified home use, I noticed this pronounced augmentation of acoustic sound produced by the large Tele bridge plate and it solidified my choice.
  12. Tonetele
    South Australia
    I am inclined to believe that a Tele has more mass than a Srat and less points where sound could leak. Also the bridge would play a part in the Tele. JMHO
  13. Velorex
    Velorex Tele-Meister
    Berlin,Germany
    Tele over Strat
    My strat sounds dull and weak against all of my teles.
    velorex
  14. RadioFM74
    RadioFM74 Friend of Leo's
    Italy and Switzerland
    Let me be the first to ask: why is the acoustic volume of a strat or tele even a consideration at all? o_O
    joe_cpwe, Owenmoney, DugT and 3 others like this.
  15. vishnu
    vishnu Tele-Meister
    scotland
    Thanks Guys :)
  16. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    wait..
    what?
    Why??
    Owenmoney and RadioFM74 like this.
  17. hemingway
    London, UK
    You need both so that the tele can feel superior to the strat. Which it is.
  18. DugT
    DugT Tele-Holic
    northern CA
    First you asked if you "Could expect...difference in volume" and then you say "The difference in volume is quiet marked".
    Maybe you meant your first question to be, "Are strats usually louder acoustically?"
    Anyway, to compare the two I think you need to put identical new strings on both guitars and then compare.
    By the way, I don't think anything on a guitar can amplify sound but hardware can attenuate sound to varying extents. Apparently I can be anal about semantics.
    Mechanic likes this.
  19. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    Acoustic sound?????
    It's an electric guitar, it's supposed to be plugged into and amp and played!
    Owenmoney and T Prior like this.
  20. Owenmoney
    Owenmoney Tele-Afflicted
    Green Lane , Pa
    Does it really matter ? And why does it matter? It’s unplugged, did you put both volumes on ten? There’s the problem! Sorry the fogs thick here this morning, outside and in my head !
    Sent from my iPad using Tapatalk
