Tele Standard saddles base material?
Discussion in 'Tele-Technical' started by zammie, Aug 24, 2019.
  1. zammie
    zammie TDPRI Member
    Kuala Lumpur, Malaysia
    Hi folks, been lurking around for some time but haven't posted. Anyhow I have a question.
    I am sanding the bridge plate and saddles on my 2012 Squier Standard Tele to remove the shiny / satin chrome look. Plan to do so for the control plate as well.
    I am using sandpaper and after getting through the chrome I hit a very thin layer of copper, which I understand is common. Below the copper I find a whiter metal, probably the base metal of the saddle. My question is, does anyone know what this metal is?
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    My guess is just pot metal.
  3. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Tone metal, a proprietary alloy. You could prime and paint orange for a unique look. :)
    stevemc likes this.
  4. zammie
    zammie TDPRI Member
    Lol...meaning like cast iron? I thought pot metal is grey, like the cheap tremolo blocks.
  5. sjtalon
    Actually, there is no real standard for pot metal (contents).
    and I am wingin' it here on what those saddles are are.
    Brass-- Not :lol:
    Happy pickin' !
  6. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    Pot metal = zinc based alloy aka zamak. Mixture of zinc, aluminum, magnesium and other odd metals. Composition can vary.
    Soft and easy to make. The chrome plating gives an element of hardness.
  7. RottenTheCat
    RottenTheCat Tele-Holic
    Drambuie, Africa
    Saddles pressure cast zinc. Plates, steel. A magnet is your friend
    zammie likes this.
  8. zammie
    zammie TDPRI Member
    Thanks chaps. Just laughing at myself for having sanded away the hardest part of the saddles. I probably swap the bridge out for a Wilkinson one with brass saddles but I might as well have fun first.
  9. RottenTheCat
    Drambuie, Africa
    The WIS call honest wear Wabi Sabi, after the Japanese concept of imperfection. I guess the same applies to guitars?
