Tele screw set for parts tele build
Discussion in 'Tele-Technical' started by branbolio, Jul 5, 2020.
  1. branbolio
    branbolio TDPRI Member
    hawaii
    I’m building my first parts tele and I need a few different screws. Neck screws, control, strap. Is there a decent priced set out there and recommended place to order them?
    Also curious is there any complete parts list for tele of all the screws and sizes/part numbers?
    tubegeek likes this.
  2. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    There is definitely a thread on this board with this exact information.
    branbolio likes this.
  3. TimTam
    TimTam Tele-Holic
    Melbourne
  4. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    Basic generic screw list
    Neck #8 x 1 3/4" oval head Phillips woodscrew
    Pickguard #4 x 1/2" oval head Phillips woodscrew
    Control plate #4 x 1/2" oval head Phillips woodscrew
    Strap #5 x 1" oval head Phillips woodscrew
    Bridge #6 x 1" oval head Phillips woodscrew
    Switch #6-32 x 5/8" round head Phillips machine screw
    Bridge pickup #6-32 x 5/8" round head Phillips machine screw
    Neck pickup depends on body or pickguard mounting. Tuners and string retainer are usually supplied with screws
  5. MarkF786
    MarkF786 TDPRI Member
    New Jersey
  6. branbolio
    hawaii
    Thanks this should help!
    Neck pickup is body mount, if you have specs for that one... I do need
  7. branbolio
    hawaii
    Dang that would be great but why no Phillips? Thanks for the links!!!
  8. branbolio
    hawaii
    Can you please point me in the direction if you know it’s whereabouts
  9. tubegeek
    Brooklyn, NY
    I'd be doing the disservice of preventing you from discovering the wonders of the "search" function!
    Seriously - I don't know and I'd just be doing the same thing, search box upper right.
    If you can't dig it up, PM me and I will rack my brain for keywords that will work.
    Search suggestions: flat head, sheet metal, phillips head, pickguard, pickup mounting.
    If you throw a bunch of those in at once, what comes back will be the posts with the greatest number of hits in them, it should work. If not, PM and I'll help you out.
    Magnifying glass icon, upper right.
  10. tubegeek
    Brooklyn, NY
    I **think*** that's a #3 1" sheet metal screw?
  11. Tuxedo Poly
    Merseyside UK
    #3 x 1" round head Phillips or slotted woodscrew.
    Fender use both types, slotted on American vintage, Phillips on Mex vintage. Seems a bit pointless when you can't see the screw head.
  12. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
  13. mikestearns
    mikestearns Tele-Meister
    Hanover, PA
    Posting so I can easily find this thread later.
  14. Jerry J
    Jerry J Friend of Leo's
    NoVa
  15. rjtwangs
    rjtwangs Tele-Afflicted Silver Supporter
    Reston, Virginia
  16. tessting1two
    tessting1two Tele-Holic
    Southern California
    If you buy slot head screws, buy the right screwdrivers so you don't mangle the screws or worse, slip and gouge yourself or the instrument. The correct screwdrivers are called parallel tip/hollow ground screwdrivers and are commonly used by gunsmiths.
  17. tubegeek
    Brooklyn, NY
  18. branbolio
    hawaii
  19. tessting1two
    Southern California
    Since you're in Hawaii and you probably don't have a decent bolt & fastener store nearby, it might be cheaper to find a local music store that is a Fender dealer since Fender forces their dealers to carry an assortment of common replacement parts. Then again, there's always Amazon.
    Here are the Fender part numbers:
    • Pickguard/control cover screws: 0994923000
    • Neck mounting screws: 0994948000
    • Bridge mounting/strap button screws: 0021422049
    • Neck pickup mounting screws: 0016295049
  20. ben smith
    ben smith Tele-Holic
    london
    ebay or amazon, i got all my screws for my build from ebay you have to buy packs but you can find them really cheap, i got mine from uk though not china but i'm sure most of it was made in china. i bought everything you would need to build a tele, every little screw electronic knobs covers pickups scrap buttons e.t.c in the end it can add up but at least you will have a load of parts laying around for another build in the future! maybe even enough parts like some of us have laying for a complete guitar build! don't going buying a switch tip for $27 that's just nuts
