Tele routing
Discussion in 'Fender Custom Shop Tele Forum' started by vishnu, May 22, 2020.
  1. vishnu
    vishnu Tele-Meister
    scotland
    My cs 52 Tele 2016 does not have the middle channel between PUPS......is that odd/unusual?
  2. vishnu
    vishnu Tele-Meister
    scotland
    Ignore Vishnu and that daft question he is not well in the head at the moment :)
  3. shadycakes
    shadycakes TDPRI Member
    Virginia
    Perfectly normal. The channel is only there because a hole cannot be drilled directly from the neck pickup pocket to the control cavity.
  4. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    Are we witnessing personality wars within this vishnu person? How many more are there?
    Yes it can, you just need a long bit.
    theprofessor and televillian like this.
  5. shadycakes
    Virginia
    From the neck pickup cavity to the bridge pickup cavity, absolutely. From the neck pickup cavity to the control cavity would require a very long bit indeed.
  6. vishnu
    vishnu Tele-Meister
    scotland
    no, no multiples....just us three
    Rasher and theprofessor like this.
  7. wabashslim
    Sonorous Desert
    Well, as long as you're all buddies. That would make me self-conscious on the toilet though.
    Those bits exist but you won't find them at Home Depot. With the chuck in the neck pocket HD's longest will get you to about an inch from the control cavity. Then you have to go in slant-wise the rest of the way. I truly hate having the neck pickup wire going to the bridge rout, then you have to take absolutely everything apart just to change the neck pickup. With a direct path all you remove is the pickguard & the pickup itself & loosen the strings a bit.
  8. Peegoo
    Peegoo Friend of Leo's
    The long bit is called an "aircraft" drill.
    Look on Amazon...you can get stupidly long ones.
    Jlwctn likes this.
  9. warrent
    warrent Friend of Leo's
    toronto
    Okay I'll bite. Ignoring the picture you posted are you saying you have a custom shop 52 without the middle channel?
  10. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    What? And no pictures?
  11. Fender-guy
    Fender-guy TDPRI Member
    Here’s a pic of mine with no pickup wiring route between the pickups. It totally is a pain to feed the wiring through! E3FFA028-F56C-4A5A-91E9-B8ED78DD4DDC.jpeg CD514846-2DD2-4B8E-8F33-00C663157DC6.jpeg
  12. televillian
    televillian Tele-Afflicted
    Clarkdale, AZ
    it might be odd and/or unusual but it`s easily fixed
