Tele PRS hybrid
Discussion in 'Tele Home Depot' started by photondev, Aug 5, 2010.
  1. photondev
    photondev Tele-Holic
    San Diego, CA
    Thinking about future projects, I combined Terry Downs' template with a PRS template I had and this is the result.
    The plan is to use a tele or a strat bolt-on neck and keep the Fender scale.
    Good idea? bad idea? Any suggestions?
    Thanks
  2. nvilletele
    nvilletele Friend of Leo's
    California
    Looks great . . . only suggestion is . . . go for it.
  3. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    What will you do for a pickguard?
  4. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    There's really no reason to have that wiring channel rout. If you plan to use a headstock adjust neck, no reason for the open slot between neck pocket and pickup cavity. Leave them out and you could go without a pickguard.
  5. photondev
    San Diego, CA
    thanks for the encouragement guys
    regarding the pickguard, I don't know yet
  6. home_brew
    home_brew TDPRI Member
    That's a great idea. I might have to do something similar in the future. I would rear route the controls if it was me.
  7. BigDaddyLH
    Jack, that's what I was thinking. With a nice wood grain or finish, you could show it off without the pickguard. In that case, I still like the Tele control plate versus using rear routing. Without the control plate, some guitars end up looking "generic" rather than "Tele"-ish, IMHO.
  8. fluid69
    fluid69 Tele-Holic
    usa
    How Ironic!
    I've been working on this template for a few days now. I wanted a thinline tele prs hybrid. I thought I was the only one. :lol:
    Haven't decided if I want tele twang or humbuckers yet. I also like the "rick" style f-hole, but when I was doing the mock-up the tele style f-hole spoke to me. For the pickguard I was going to go with the mira style and do front routes. I also put a radius @ the neck pocket to help tie it in.
    You'll probably get to your's first, (I have three builds I'm trying to finish), please let me know of any problems you run into. I'd like to see someone pull it off.
    P.S. Have you thought about the headstock yet?
  9. photondev
    San Diego, CA
    fluid69 - great minds think alike :lol:
    I still have one build to finish, but probably I will start earlier than you
    I see that you rounded the neck pocket, I think I will leave it as is in my template
    the only things I have decided about are:
    1 piece African mahogany that will arrive next week
    neck will be eithera MIM strat neck or a tele Squier neck, I have both already
    P90s or humbuckers
  10. fluid69
    fluid69 Tele-Holic
    usa
    wow, African mahogany sounds awesome! Yeah, when I saw the title of your thread and then your template with the f-hole, I knew we we're both on the same page. I rounded the neck pocket into the body because I thought it would give it a little more support, plus I thought it would be easier to finish, (seems like a bad place for overspray to accumulate). I would like to see what it looks like with a strat or tele headstock, although I've been thinking about building a neck with a prs headstock. I'm not sure yet either.
  11. photondev
    San Diego, CA
  12. cpeters01
    cpeters01 Tele-Meister
    Edmonton, AB, Canada
    I think Ed Roman does a PRS style (Quicksilver) guitar with a bolt on that extends under the front pickup so the cutaway and neck pocket are eliminated...you may want to check it out.
    http://www.edroman.com/guitars/quicksilver.htm
  13. photondev
    San Diego, CA
    Started the build. I decided to get some 8x2x2 pine from Home Depot.
    template:
    and roughly cut body:
  14. photondev
    San Diego, CA
    I don't have a router yet, there was a very good deal in craigslist for a mint/new Porter Cable 690 with the plunge accessory for $100, but somebody else got there first. So I ordered a new one, just the 690, should be here early next week.
  15. photondev
    San Diego, CA
    talking about tools, this Harborfreight clamp couldn't stand the pressure and broke
  16. Stubarber
    Stubarber Tele-Meister
    Houston area
    Quite interested in this project. Where's my popcorn?
  17. middy
    middy Friend of Leo's
    Dallas, TX
    Why is it all rusty where it broke?
  18. photondev
    San Diego, CA
    good question, it was brand new
  19. photondev
    San Diego, CA
    I finally got a router :D - WOW what a difference
    I finished the body template, I'll post pictures tonight including my rookie mistakes, but the template came out great
    I will start working on the routing template later today, and I have a question regarding pickup hole placement.
    Let's say I want to put P90s or humbuckers, how do I go about deciding where to put them ? thanks in advance for your suggestions
  20. photondev
    San Diego, CA
    here are the 3/4" templates:
    body template
    routing template
