Tele pickup specs
Discussion in 'Just Pickups' started by GuitarJonz, Dec 22, 2008.
  1. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    Below is a comparison of specs on a number of tele pups I've had over the years. There are others too before I started measuring & keeping track (Rio, VZ, Fender, Duncan, BL). I know that resistance readings don't mean anything re output, but here goes.
    Re the Weider vintage tele, he let me measure the pups at a show, while in the guitar, I compensated for them being installed by adding .25k ohms, per Don Mare.
    Tele pickup values
    Resistance in Ohms
    Weider ’52 tele NECK 6.29k
    #4248 BRIDGE 7.28k
    Don Mare 1965 BRIDGE 6.8k
    (Green Onions)
    Fender MIM 50s NECK 7.27
    Duff Nancy NECK 7.2k
    BRIDGE 5.9k
    52 RI (post 1998) NECK 6.52k
    Hamel Tall NECK 6.3k
    Hamel Std BRIDGE 7.2k
    Hamel B’caster BRIDGE 8.3k
    Suhr Classic T BRIDGE 7.69k
    (V60's Low Peak)
    Harmonic Design NECK 5.92k
    Vintage Plus BRIDGE
    Joe Barden NECK 4.53k
    BRIDGE 4.69k
    Keystone NECK 5.15k
  2. Southpaw Tele
    Southpaw Tele Friend of Leo's
    The Golden State
    Any clue where I can find resistance values for a 2007 MIM Standard Tele?
  3. teleftcaster
    teleftcaster Tele-Meister
    Oklahoma
    Fender site may have it. Other than that, you can check it yourself with a cheap multimeter. It's pretty easy to do.
  4. twangcaster1
    twangcaster1 Friend of Leo's
    Nashville, TN
    Multimeter would be the best way to get an accurate value, in my opinion.
  5. Zhangliqun
    Zhangliqun Tele-Meister
    Los Angeles
    It does mean something in context with other factors, it's just not the sole determiner of output.
    Don's right. Also be aware that the readings will shift quite a bit with changes in temperature. Colder = lower reading and vice versa.
  6. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    I have a 2006 Nashville Tele (which would be the same pups) I removed and they were:
    Bridge 8.11K
    Neck 5.9 K
  7. pchilson
    pchilson Friend of Leo's
    Arkansas
    So how do you measure output? Can that be measured out of the guitar?
    Can you make any correlation of the resistance to the output in a general way?
  8. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    The MIM Deluxe Nashville Tele pups are the Tex Mex Tele pups; those readings above are fairly consistent (although the bridge's DC resistance is sometimes higher) with both what I've measured and what I've read from others' accounts.
    I believe the MIM Standard AlNiCos (not the current ceramic version) are a different spec, accounts I've read indicate the neck is usually close to but a little under 8k.
    I have some readings I've collected from several different models. It would be good if we could get them into a database and have a way to display them in a tabular format here that all could read. Mine are in an Excel spreadsheet.
  9. bolt5
    bolt5 TDPRI Member
    Boston area
    When researching pickups I found a vintage fender spec chart at http://www.provide.net/~cfh/pickups.html. We were trying to determine if we were getting the right output from our tele. Seymour Duncan has some good info on their website. We did a quick comparison on our three guitars ( strat/ LP/ tele) by checking the resistance from signal to ground at the cable jack - it read lower than the pickup spec, but was good on a relative basis and was noninvasive. I think we got that tip from a post here.
  10. GuitarJonz
    MA
    To measure pickups in a guitar, I use a multimeter, set on 20k ohms, and a shortie cord (as used between pedals), with pots on full. Plug one end into guitar, touch one lead to the tip of the plug, the other to the shaft, then add .25k ohms for a pretty accurate reading.
  11. pchilson
    Arkansas
    I take it your talking about measuring the resistance?
    Is there a way to get the output measurements?
    How do I measure how hot or not a pickup is?
    thanks
  12. sjtalon
    Ohms is a resistance measurement-more wire = more resistance.
    More wire = more powerful voltage generator.
    Pickups generate a voltage, so if you had a meter that read LOW enough you would get some reading but generally speaking, the resistance reading in comparing one pickup to another can determine how "powerful" it will be, with all other things being equal, i.e. the inductance of the pickup, the type of magnet, position of the pickup (bridge or neck).
    The higher the resistance ("hotter" pickup), the more voltage it puts out to drive the amp .........that's the short version.
  13. pgambon
    pgambon Tele-Meister
    DiMarizo used to (and may still) measure peak output hitting a "A" note. Great idea but unless every manufacturer complies to an exact procedure, comparisons would be useless. For Tele pups that are mostly similar, ohms is a good indicator. Other factors to consider would be wire gauge, magnet type, potting and scatter wind (or not).
