mountainhick
I have a douglas fir tele body in progress, hopefully will get to rough cutting shape and making a routing template from my MIM tele today.
I am going to build a neck from scratch (actually more than one). I have some biases about construction, but want to run them by the quorum, along with other questions. I am not concerned about traditional construction, but I do care that the tone is all Tele.
1- I've always found Fender's flat neck construction with string trees kind of stupid functionally, though brilliantly simple in terms of production. So. scarf joint? If so, how much back angle is needed to do away with string trees?
2- I have a couple double action truss rods, so route from fingerboard side, and adjustment at headstock. I have not used these before. Any considerations peculiar to these?
3- Seems to me that multi piece with intelligent grain orientation will result in better neck stability. A single slab whether flat or riftsawn has more tendency to twist/warp, so i am thinking of doing a couple of opposed grain halves, perhaps with a center stripe piece. Yay. Nay?
4- Wood type. I have more of this Doug fir, some of it is very tight grained and dense. Are there noticeable differences in tone and stiffness and stability between different neck woods? I do not want to veer off the bright snappy character of a real tele tone wise. I also have maple, koa, birch, hickory and a few odd ball wood types. The body will be medium weight, so I don't want to use anything too dense that will neck dive.
5- Dimensions: i am looking forward to a tiny bit wider nut! 42mm necks jam my fingers together too tightly when chording in open position. I am unsure though about thickness. All of my guitars have seemingly modern slimmer depths, which are generally comfortable, but I don;t know anything different. This is why I plan to build at least a couple necks, to try out different sizes/shapes. I know the general dope about shape, C vs D vs U vs V etc, but what are typical neck depths at nut or first fret, for slim to medium to fat?
