Tele Dimension Question.
Discussion in 'Tele Home Depot' started by Oldtimer47, Jun 9, 2011.
  1. Oldtimer47
    Oldtimer47 TDPRI Member
    California
    The heel or end closest to the neck pup on the neck route is 2.224 according to the print.So why does everyone say in their advertisements say that it is 2 3/16"?So when you make them for sale,which dimension do you make on the route?Any held would be appreciated.
  2. Stoked
    Stoked Tele-Meister
    Huntington Beach, CA
    I don't have a definite answer for you, but if you have a fender made tele measuring it's neck pocket might help you with your decision.
  3. Fred_Garvin
    Fred_Garvin Tele-Holic
    Atlanta, GA
    That is only 36 thousandths of an inch difference, it would be hard to measure without a micrometer or something similar.
    It's well within tolerance in that dimension, considering you have 2 layers of finish, fret height, string pull, plus a truss rod and adjustable bridge to compensate still to come.
    CNC wouldn't be much more accurate than that.
