Tele Buzz
Discussion in 'Squier Tele Forum' started by MusicBill, Oct 25, 2020.
  1. MusicBill
    MusicBill TDPRI Member
    NJ
    I am working on a Squire Tele for a family member and I am getting a loud buzz. I just replaced the output jack. I checked the wiring and it is good. The Buzz gets louder when I touch the strings. I checked it on a tube amp, Im going to try a solid state amp,but I am wondering what would cause this. It sounds like a ground issue but Im not sure. Any ideas?
  2. SbS
    SbS Tele-Holic Silver Supporter
    Finland
    Can take some pictures under the hood, like control plate cavity and output jack? Should be vice versa with the noise.
    Also, did that amp worked normally before?
  3. MusicBill
    NJ
    Yes no problems with the amp. I tried 5 other guitars with no issue. What do you mean vice versa with the noise?
  4. SbS
    Finland
    When touching the strings, noise should go quieter. You ground yourself via strings when playing.
  5. MusicBill
    NJ
    Ok it gets louder when I touch the strings so it sounds like there is a ground problem in the guitar itself?
    Wallaby likes this.
  6. SbS
    Finland
    Yeah, I think so. Good news is that that amp is probably ok, that could be even dangerous.
    Sometimes knowlegeable people here can spot problems if there are good photos to show. But sometimes just need to double check and redo everything again. I did that few times last spring ;)
    I'm not a pro, but there are some very experinced ones here.
  7. Wallaby
    Wallaby Tele-Afflicted Silver Supporter
    Midwest
    Could the leads to the output jack possibly be switched accidentally?
    LutherBurger likes this.
