Tele bridge replacement
  • Thread starter stevekolt
Maguchi
Lalaland
Yes, but my understanding is that @stevekolt's guitar is an MIM Standard Tele.
I've put both Fender '52RI and Wilkinson ashtray bridges on multiple MIM Standard Teles. The only thing I ever worried about is if the original plate left a visible imprint in the finish since it has a larger footprint than an ashtray.
The only guitars I've ever seen with the four mounting screws with string-through holes closer to the endpin that have had issues with a regular Ashtray dropping in have been Glarry Teles. For some reason the bridge pickup route isn't in quite the same spot and I had to route a tiny bit of wood out to make it work.
Heck, the string-through Affinity Teles with the belly carve take an ashtray bridge no problem! The only problem is that you can see a sliver of the bridge pickup route on the bass side of the plate, but my wife doesn't care all that much. I did have to cut the replacement pickguard out a touch around the neck and bridge cutouts to make that fit, but then even all the screw holes lined up.
I recently replaced the 6 saddle bridge on my 2019 MiM Player Tele with a Gotoh BS-TCIS T-style bridge with compensated saddles https://www.sweetwater.com/store/detail/BSTC1SCR--gotoh-bs-tc1s-t-style-bridge-chrome and some Fender Classic Gear Tunng Machines, https://www.sweetwater.com/store/de...ssic-gear-machine-head-tuning-machines-chrome for a classic old school look. They both fit and work great on a MiM Tele. IMHO old school looks, but modern performance. All holes are in the right place. No drilling needed.
BluesOwl
MI
@stevekolt
Wait!
Glendale glendaleguitars.com has the 3-saddle raised lip tele bridge plate you want. 3-hole mounting.
stevekolt
WV
Alrighty, bridge delivered from SW today.
Fender 3 saddle American Vintage Telecaster Bridge Assembly is a direct replacement….Yay!!!
Gotoh compensated saddles ordered.
Very happy.
Big thanks to Scott A. at Sweetwater.
Thanks to all for the suggestions/help.
John Stephen
S.F. Bay Area
OK thanks @BigPapa-53 . Looking back at your photos, I wouldn't have thought the replacement bridge, which is much shorter than your original bridge, could be a drop-in replacement. But I guess it can. I hadn't picked up on that, back when you posted your post.
yegbert
Maryland
The length (of a seemingly longer flat block-saddled bridge like an MiM Standard, or the similar GOTOHs or Klusons) is misleading. It’s the footprint of the pickup hole, STB, and screw holes that matters. If that footprint matches, it fits. If that footprint doesn’t match, get out a drill or go home.
John Stephen
S.F. Bay Area
Right, that’s why I was never able to find a 3-saddle replacement bridge for my Bullet Tele, which has a 6-saddle. The holes didn’t match up. Also, because the 3-saddle bridges were all about 15 mm shorter, the screw holes at the back end of the bridge would have been uncovered and visible.
Ron C
Long Island, New York
I want to replace the six saddle original bridge on my MIM Tele with a three saddle compensated bridge. The Wilkinson is too short, see pics
Original
Wilkinson
Sorry for the quick and dirty pics. Any help/suggestions would be appreciated.
@stevekolt I'm really glad this worked out for you. Something was fishy about the original problem. I feared that your MIM Tele was actually a fake, since I've never seen a MIM Tele that couldn't be fitted (without drilling) with a vintage style, Fender-spec bridge*. Thankfully that's not the case!
Equally weird is that the Wilkinson bridge didn't fit -- I thought they were all standard-spec. Not so, I guess.
*Exception might be some really early MIM Standards...were they top loaders?
yegbert
Maryland
I don’t know the specific measurements of the Bullet Tele, but the bridge that Fender shows on them online look enough like the [now discontinued] 2K and newer Squier Standards, that with some adaptation a Kluson hybrid for American Standard Tele might fit; if its STB holes are compatible, the bridgeplate or Tele body might mount.
yegbert
Maryland
I think that early ‘90s MIM and Squier (except for some MIK ones) Standards were toploaders.
John Stephen
S.F. Bay Area
Thanks for that. Back when I was trying to do this, I looked a bunch of bridges online, but i can’t remember if I looked at this one. I will see if I can track down the dimensions of this one somewhere online.
