Tele bridge pickup bizzing
Discussion in 'Tele-Technical' started by zac jessup, Sep 18, 2020.
  1. zac jessup
    zac jessup TDPRI Member
    Hey guys, I have a 2012 tele with a buzzy bridge pickup. When I touch the pickup it buzzes very loudly, but if I touch any other metal part on the guitar, the buzz is reduced but not gone. I have checked all the grounds and also flipped the polarity but with no success. My thoughts are the pole peices are somehow hot? The pickup is a lollar vintage. There's a little bit of rust on two of the pole peices but nothing major.
    Cheers
  2. zac jessup
    I have also tried wiring the pickup straight to the output jack which also didn't help
    LAPlayer likes this.
  3. Ess Eff
    Ess Eff Tele-Afflicted
    Have you got a ground going to your bridge plate?
    Bartholomew3 and zac jessup like this.
  4. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
    Is there a chance you wired it backwards, inverting the hot and the ground leads?
  5. zac jessup
    I do yes
  6. zac jessup
    I tried reversing them but to no avail
  7. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    Take a multimeter and check the resistance between the poles and ground.
    zac jessup likes this.
  8. zac jessup
    Ok I'll try that! I'm guessing I should be seeing 0 ohms?
  9. EsquireBoy
    Paris, France
    Then I really do not think of anything else other than a faulty pickup. As you say and IME the symptoms you get are really evocative of the pole pieces being hot.
  10. hamerfan
    Germany, Bavaria
    That would show that the inner windings have a connection to the pole pieces.
  11. zac jessup
    I should also add that It buzzes when I touch the bobbin of the pickup as well. Would this happen if the pole peices are hot?
    I'll measure the resistance between the pole peices and ground then report back on the readings.
  12. zac jessup
    The resistance between the pole peices and ground are too high to read. Same with the hot lead to the pole peices
