Tele 4 way wiring w/ Humbucker Neck pickup ?
Discussion in 'Tele-Technical' started by jads57, Jun 2, 2020.
  1. jads57
    jads57 TDPRI Member
    St.Paul,Mn.
    Thanks to everyone for their input! I need to digest it so I understand it a bit better.
  2. 63 vibroverb
    63 vibroverb Tele-Afflicted
    Lititz, PA
    As long as you set your bridge pickup to be a good bit louder than your neck pickup, your combined positions will be sweet and clear with no mud. Set that humbucker low.
    jads57 likes this.
  3. jads57
    jads57 TDPRI Member
    St.Paul,Mn.
    Thanks Again to everyone for their time and knowledge. MUCH APPRECIATED !
  4. studio.ku
    studio.ku TDPRI Member
    Paris FRANCE
    Hi everyone , very interesting topic !
    Moosie , could you indicate wich position is 500k or 250k in your shema ? thanks !
  5. moosie
    Western Connecticut
    In that diagram, every position in which bridge is active, the pot has the resistor in parallel, bringing the 500k down to 250k. The only time it's not used is Neck position.
  6. studio.ku
    Paris FRANCE
    I tested the wiring, it sounds out of phase when the switch activates only one humbucker coil, big volume drop and thin sound ... how can I fix that ? although it sounds good with the neck and bridge together...
  7. moosie
    Western Connecticut
    There will always be a volume drop when going from a humbucker to a split. Two coils in series, vs one coil.
    When you say out of phase, is this the split coil alone? Or in parallel with bridge? Because one coil alone can't be out of phase. Compared to what?
  8. studio.ku
    Paris FRANCE
    Moosie you're right , the same thing happens with only the neck pickup is engaged , drastic drop of volume and thin sound , so no out of phase beetween the two pickups.
    may be my humbucker has a differrent cables color code ? I will check that.
    surprisingly the fourth position , with two pickups in series , is not too muddy and adds a pleasant mid boost , but both neck/bridge position would benefit of a 500k .
    so is there a 4 position wiring possible with 500k impedance when both pickups are engaged ?
    thanks
  9. moosie
    Western Connecticut
    500k. Sorry, no, not possible. You'd need a super switch.
    OOP. Are you saying it sounds thin with the full neck humbucker, alone? Not split? If that's the case it might conceivably be wired out of phase, internally.
  10. studio.ku
    Paris FRANCE
    Neck pickup sounds ok when there's no split.
    here are the sounds : Bridge / bridge + Neck parallel / bridge + Neck parallel splited / Neck / Neck splited / bridge + Neck serie / bridge + Neck serie splited
    it's an Ambers humbucker , no info on their website about the color code
    any ideas ? I checked the wiring again , everything is right.
