Tele 4 way wiring problem
Discussion in 'Tele-Technical' started by lespowl, Feb 13, 2020.
  1. lespowl
    lespowl TDPRI Member
    Hamburg, Germany
    Hey y’all,
    I got a problem I can‘t seem to figure out myself.
    I installed a 4 way Setup into my partscaster build. Did the grounding on the neck pickup cover and wired after the usual diagram.
    Problem now is that the 1st position / neck only is dead, then 2 and 3 work, but 4 is no difference at all to position 3.
    Does this ring a bell to anyone?
    Don‘t know what to look for.
    Thank you for your troubleshooting.
    Paul
    since71 likes this.
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Loosen the switch screws and try it. Often the slot in the control plate is not long enough for the lever the throw all the way.
    You can file the slot longer if that's the problem. I used a real fine hacksaw blade.
    I tap the pickups with a paper clip when going thought the switch positions to verify what should be on or off. You can tell the difference between series and parallel as the series tap is muffled/darker or not such a tick tick tick.
  3. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
    Post a picture of the wired up switch.
    Somebody will spot your problem pretty quickly.
  4. eallen
    eallen Tele-Afflicted Silver Supporter
    +1. You can also notch the switch lever where it contacts the switch plate on each side with a file.
    Eric
  5. lespowl
    Hamburg, Germany
    Hi all,
    thank you so much for your help.
    The control slot is fine, I just checked it, but with it I found a spot that I missed when soldering.
    Now it is as follows: pos. 1 is still dead, but all other positions from 2-4 work, including the neck pickup.
    Why is just pos. 1 dead?
    Here‘s some pics, that might help solving
    It.
    4BAE56AB-58F3-45E0-AE3A-2A6B8B30F35B.jpeg 4E92DFAF-60C7-456D-96AC-DC7E7C815D91.jpeg 544C52CC-4939-40AF-9A70-EBB2EC8748DF.jpeg
    Thanks again for your help.
    Paul
  6. LowCaster
    LowCaster Tele-Afflicted
    Paris, France
    What wiring schematics did you follow? Most of them feature a jumper going from left to right.
    Mine follows a different layout (neck/series/parallel/bridge) but you’ll see the black wire in the center of the switch:
    since71 and Kevin Wolfe like this.
  7. Telecentric
    Telecentric Tele-Meister
    Boulder Creek, Ca
    From the pictures, I'm going to guess a cold solder joint somewhere. All solder joints should be smooth and shiny.
    Bendyha likes this.
  8. ClashCityTele
    ClashCityTele Tele-Afflicted
    Washington, UK
  9. lespowl
    Hamburg, Germany
    Hm, it might be the wire going from left to right. That one‘s missing in my schematic. For whatever reason...
    I‘ll try it tonight and see if it works.
    Many thanks.
  10. LowCaster
    Paris, France
    And double check that you did not swap the neck and bridge wires.
  11. Diytelecaster
    Diytelecaster TDPRI Member
    Also check if the cavity is deep enough. I went from a box switch to an oak grigsby and I had clean out the cavity a smidge to get it to switch cleanly.
  12. lespowl
    Hamburg, Germany
    So I tried the wire going from left to right, soldered it and now everything works just fine.
    Best decision to install the 4-way. Sounds killer!
    thank y’all again. Great help. Much appreciated.
    Paul
    WingedWords, eallen, danlad and 2 others like this.
  13. sjtalon
  14. lespowl
    Hamburg, Germany
    BTW. Here‘s the final project: an Mjt build blackguard. maybe the best sounding guitar I own.
    happy tellysunday.
    milocj, ClashCityTele, moosie and 2 others like this.
  15. LowCaster
    Paris, France
    Beautiful guitar!
  16. sjtalon
    spectacular !!!!!!
  17. sleazy pot pie
    sleazy pot pie Tele-Afflicted Silver Supporter
    austin
    Nice looking guitar
    What pickups?
  18. lespowl
    Hamburg, Germany
    Went with Fender Nocaster 51s as a start. They sound pretty good but I also plan to try other sets like the Lollar Ts or such. Any recommendations?
  19. ClashCityTele
    Washington, UK
    No problem. When I first did my 4 way switch, the tone control didn't work at all.
    It sounded ok, but I thought I'd better put it right.
    Best mod ever.
  20. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Glad it worked out!
    A rare problem that once happend to me: the coil of the neck pickup shorted out against a polepiece (which then touched the cover). It was the ground side of the coil, so it still produced a sound, but wouldn't work in a 4-way. Took me ages to isolate the problem...
