Teflon Tape or Thread Compound for leaking 3/4" pipe fitting?
Discussion in 'Bad Dog Cafe' started by DugT, Jul 11, 2019.
  1. DugT
    DugT Tele-Holic
    northern CA
    It is possible that it is not leaking now. If it is just slightly leaking in the morning, I will try tightening it a little more. If that doesn't work, I will take it apart, clean it, and reassemble with teflon and a bronze coupler. The previous steel tank lasted 16 years with no sign of corrosion at the copper fitting so maybe the steel (I assume steel) threads were coated with something so a bronze coupler isn't necessary.
    The threads should be good because copper doesn't rust and the tank is new.
    I only coated the male threads with compound and I put it on fairly thick. Then I screwed it into the copper fitting by hand until it was tight enough to require a wrench, which was at least three full turns later. After I got it tight with a wrench, I wiped the exposed male threads to see was what going on. Since then I got better wrenches and wrenched it tighter so the compound is being squished thicker at the intersection.
    I took photos of the back of the copper nut section and I see no cracks.
    One way or another, I will solve this problem without any TDPRI members flying out here.
    Obsessed likes this.
  2. Hobs
    Hobs Tele-Meister
    Nashville, TN
    A very slow leak will usually stop leaking after a day or two, as minerals in the water make a seal. Then it will wait, with unimaginable patience, for decades if necessary, for the very most inconvenient time to fail entirely.
    stratofortress, DugT and Milspec like this.
  3. Wallo Tweed
    Wallo Tweed Friend of Leo's
    Penns Wood
    I'm not a plumber, but I did stay in a crappy motel last night. It sure looks cross threaded to me.
    Toto'sDad and Milspec like this.
  4. Milspec
    Milspec Friend of Leo's
    Nebraska
    Especially when you are dealing with steel connecting to soft copper
  5. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    I'm gonna hazard the copper got stretched from the original torque up and so long as it isn't cracked AND your male end isn't bottoming out on the shoulder inside the copper you can torque it sealed. If the male end is actually bottoming out, you need to replace the
    female side.
  6. DonM
    DonM Friend of Leo's Silver Supporter
    Henderson,NV/SLC,UT
    I'm a Teflon Tape guy. Great stuff.
    OldDude2 and Owenmoney like this.
  7. Stringbanger
    Stringbanger Telefied Ad Free Member
    West O' Philly, PA
    If you have to take it apart and clean the threads, use a good wire brush to do so.
    DugT likes this.
  8. magicfingers99
    magicfingers99 Tele-Afflicted
    atlanta
    teflon tape...
    how many wraps? well when I asked the fellow, he told me you wrap it until it stops leaking (ie seals the void).
    don't be stingy with that stuff, it really work
    thats an old school pipe joint., looks like hemp thread in there to fill the voids. step up to some teflon tape.
  9. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Bakersfield
    I thought that, but for some reason didn't want to be the first to say it. Glad you did.
    Wallo Tweed likes this.
  10. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    My uncle is a retired plumber. The best advice he ever gave me was "Never eat any of the chocolate donuts on the counter at the parts house."
    DugT and Sean Mac like this.
  11. DugT
    DugT Tele-Holic
    northern CA
    Problem solved. It was still leaking slightly after the last time I tightened it but it hasn't leaked at all since last night so I think I finally got it tight enough. Part of the problem, other than my weak arms, is it was in an awkward overhead position.
    From now on I will use teflon tape on this type of fitting because it is so much easier to get a tight fit with it.
    If it was cross threaded I think it would have leaked a lot no matter tight I got it.
    Thanks for all of the help!
    PS: I'm so glad RodeoTex didn't have to come here to fix it.
  12. TwangToInfinity
    TwangToInfinity Tele-Holic
    Twangville
    yes they really are great, sooo handy, every place with water pipes should have a standby kit with some of those slider connectors!
    theyre such quick and easy problem solvers!
    ce24 likes this.
  13. Owenmoney
    Owenmoney Tele-Afflicted
    Green Lane , Pa
    If all else fails, use FLEX SEAL
    Sent from my iPad using Tapatalk
