Tc electronic flashback
Discussion in 'The Stomp Box' started by Maxtone, Apr 15, 2015.
  1. Maxtone
    Maxtone TDPRI Member
    Ireland
    Hi Folks, I have a tc Flashback for several months now and have been trying to replicate U2s Where the streets have no name delay but just can't get there. Any help would be great. Thanks
  2. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
  3. asatbender
    asatbender Tele-Holic
    Calhoun, GA
    Use the 2290 preset, audio tap( strum) your tempo to quarter notes, strum on 1, 2, 3, 4. Then change the toggle switch to bottom for dotted 8th + quarter notes together.
    If you are only running mono through one amp run a patch/jumper cable from the stereo in to the mono out. This will allow you to hear both quarter/dotted 8th through a mono setup. If you have two amps, it can sound glorious in stereo. I hope I have told you right on the connections, I do not have pedal in front of me to verify. You might start out playing the song "Bad" to get the hang of it.
  4. Maxtone
    Ireland
    Cheers for the replies. Will try both. Thanks again
  5. heshan
    heshan Tele-Meister
    Colombo
    Hi. I'm also a TC Flashback user, and I'm very interested in the Edge-type delays - with the quarter+dotted 8th setting on the Flashback. I don't understand what asatbender said, though...about using a jumper cable from stereo in to mono out. I run a mono set-up, usually...mono-in/mono-out to one amp. Is this something I could try to improve the delay sound?
  6. RyanJH
    RyanJH Tele-Meister
    Can't hurt to try. Plug guitar/previous pedal into the "Mono In", run a short patch cable from the "Mono Out" to "Stereo In", and the "Stereo Out" becomes your new output. Just clarifying that.
    -Ryan
  7. heshan
    heshan Tele-Meister
    Colombo
    Thanks for clearing that up, that was exactly what I was unsure of. I'll try it ASAP. Cheers
  8. asatbender
    Calhoun, GA
    Flashback Edge demo
    Here is my sloppy try at Edge "Bad" a few months ago. I had the toggle switch all the way down. I think I had two amps running in stereo and mic'd between them.
    https://soundcloud.com/telecastermus/bad-cover
  9. heshan
    heshan Tele-Meister
    Colombo
    That's a great delay sound you got there. I've only tried the Flashback in mono so far...and I definitely hear the difference in the third position on the switch - and I know it'll sound a lot better with two amps, but I want to know how different it'd sound with the jumper cable
