Taking the leap to non tube
Discussion in 'Amp Central Station' started by golfnut, Aug 5, 2021.
  1. golfnut
    golfnut Friend of Leo's
    Well I've been agonizing over what second amp in order for me to leave my heavy 67 Pro Reverb at home with the exception of the occasional outdoor gig (maybe couple times a year) So I wanted something light and easy for practices and club gigs.
    I didn't want to spend too much so my tube considerations were a Blues jr IV, Custom pro reverb (although not exactly feather light) I was also looking at a used Peavey classic 30 that was available locally. The compromise for me was that these amps would likely not sound as good as my 67 pro reverb, still have tubes and maintenance to worry about and I'm not as fond of a 1X12 cabinet as I am of 2X12.
    So I had my local Long and Mcquade put aside a Tone master Twin Blonde aside for me till I get there on the weekend.
    As far as I can see my pro's are 2X12 speakers, light and no tubes to worry about. As well from almost every source I've researched the tone masters are very close to a tube sound. The cons are Many have said it doesn't respond to touch like tube amps. I realize there will be some things that won't measure up to my pro reverb but if I buy a 1x12 tube amp like the blues jr, I imagine there will be things there that won't measure up.
    I have 30 days to evaluate and return if thats my prerogative. The last SS amp I ever had and gigged with was a Fender Pro Roc 1,000 that I had back in the late 80's and gigged for a short while. I remember not really liking that at all but I tolerated it for a while. I'm hoping these Tone Masters are far above that.
  2. Boreas
    Boreas Poster Extraordinaire Silver Supporter
    Adirondack Coast, NY
    Good luck!
  3. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    Tubes are a pain and they are far from essential.
    Tele_Luvr, Tim S, 19sixty3 and 2 others like this.
  4. naveed211
    naveed211 Friend of Leo's
    Iowa
    Good luck. If that one doesn’t work out for you, I’d recommend giving Quilter a try before giving up and going back to tube.
    Who knows, maybe you’ll just want a tube amp again. But Quilter did it for me, and I had been a tube snob for decades. Not anymore.
    pugnax, brown2bob, jays0n and 3 others like this.
  5. golfnut
    Yes I've been reading about Quilter lately and have been curious. I'm sure if the tone master gets me 90% of the way there then I'll be content for my uses. However I still may try a quilter at some point for an additional option.
  6. michaelsegui
    michaelsegui TDPRI Member
    Tillsonburg, Ontario, CANADA
    I am an out and out snob... but after A/B'ing against vintage and new versions in the store I ended up getting a Tone Master Deluxe Reverb. I only play at home. Zero regrets. Good luck.
  7. golfnut
    One of my biggest curiosities is how my Kingsley page will sound with it. I use it in front of my amps to give that edge of breakup sound when I can't get my tube amp opened enough. If it works out well I may give one of the Kingsley preamps a try.
  8. stormsedge
    stormsedge Poster Extraordinaire
    E. Tennessee, USA
    Quilter;).
  9. ChicknPickn
    ChicknPickn Tele-Afflicted
    Ole Virginny
    I recently pulled a 70s Kustom 1 Lead combo out of mothballs and plugged her in. Gotta say, what with its real spring reverb and true gain knob, it sounded pretty darned good. And loud. Especially clean.
  10. Cheap Trills
    Cheap Trills Tele-Afflicted Silver Supporter
    NJ
    You're cool kid card has now been revoked.
    Greg70 likes this.
  11. J. Bonkosky
    J. Bonkosky Tele-Holic Silver Supporter
    Seattle Washington
    You should give the Roland JC-40 a look as well. You can dial in the tone stack to work with whatever dirt pedal you have.
  12. corbo
    corbo Tele-Meister Silver Supporter
    Upstate NY
    Still loving my Blues Cube Artist 212
    DaphneBlue, Nahtabot, PhredE and 2 others like this.
  13. golfnut
    Is that 2X10 or 2X12? I'm not fond of 10" speakers.
  14. Addnine
    Addnine Tele-Holic
    New England
    Everything I own is tubes except for a couple of older Cube 30's. I'm just continually drawn back to those for anything clean, jazz in particular, even though their treble can have a little too much sizzle for that genre. Nothing sounds nicer played quiet for some reason.
    DaphneBlue and jays0n like this.
  15. jays0n
    jays0n Tele-Holic
    San Francisco, CA
    I sold my larger Tube amp quite a while ago and use a Quilter head with a 1x12 cab and it is awesome. I do still have a small Champ tube amp for kicks.
    I think vid does the best job of showing how close the Quilter comes to a tube amp sound:
    DaphneBlue and PhredE like this.
  16. jays0n
    jays0n Tele-Holic
    San Francisco, CA
    Wanted (want) one of these but they are a bit pricy. Sound great though.
  17. brookdalebill
    Austin, Tx
    I am a convert to the incredibly versatile Roland Cube 80 series.
    I became an unwavering convert 12 busy years ago.
    I used nothing but tube amps prior to this, beginning in 1973.
    I still like tube amps.
    I just no longer own, move or repair them.
    The Cubes do all my tricks, and never falter.
    I have 4.
    You might audition one, or the similarly great sounding, comparatively lightweight Blues Cube, Katana, or Nextone series.
    I’ll get another tube amp some day
    I want one for home use.
    I’ve almost forgotten what a tube amp behaves like.
    39martind18, DaphneBlue and PhredE like this.
  18. DeepDangler
    DeepDangler Tele-Holic
    Mequon, WI
    A good compressor pedal can liven up a dry solid state amp. A gig worthy solid state amp can be touch sensitive but they have volume spikes since there is no compression. With a compressor, you can get really good feel and a smooth sound out of something that is much lighter in weight.
  19. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    i'll be interested to hear how well you like the TM. I've been toying with getting one myself, the deluxe reverb is what i'm considering. from a tone perspective, i have no problem with solid state amps, modeling amps, whatever you want to call them, but from a controls and aesthetics perspective, i dislike many of them. the TM is interesting because it retains the same control face as the tube amp its modeled after. give me 1 good voice, rich in tone, with reverb and trem, in a super light package. that's what i find attractive about them.. not to mention the super quiet noise floor.
    Ronzo and 39martind18 like this.
  20. golfnut
    Yes I'm excited to see how this amp responds with my pedals. The pedals on my board that are always on are a Cali76 CD and a Kingsley page set for slight break up when I dig in.
    DeepDangler likes this.
