Taking necks off guitars
Discussion in 'Bad Dog Cafe' started by Minivan Megafun, Sep 30, 2020.
  1. sjwieczorkow
    sjwieczorkow Tele-Holic
    Milwaukee
    My Esquire has the truss rod adjustment at the heel of the guitar. Luckily, I can just take the pickguard off to adjust since there is not a Neck pickup in the way of the screwdriver.
    My Strat has the adjustment at the butt end of the guitar too. So, I got some neck inserts from forum member Chet Johnson and now I can take the neck off and on as many times as I want as the seasons change for slight adjustments.
    galaxiex likes this.
  2. TheGoodTexan
    TheGoodTexan Super Moderator Staff Member Ad Free Member
    Nashville, TN
    Admin Post
    This.
    Boreas and teletail like this.
  3. Fender-guy
    Fender-guy Tele-Meister
    The great Joe Bonamassa says a similar thing about pulling necks in his nerdville YouTube tour.
    Well most of us don’t have the pleasure of buying a vintage guitar off the original owners with all paperwork and pics of it new with owner. We’re doing local deals and guitars shops that sell some shady gear.
    JJLC and Boreas like this.
  4. Danb541
    Danb541 Tele-Afflicted
    Oregon
    If you are in the camp that removing necks is bad, don't buy a 22 fret telecaster. If you ever want to change your pick guard you will likely have to take the neck off, not always (depending on how the neck pickup route is), but likely.
    Personally, I don't see why a neck would be removed more than a handful of times throughout the life of a guitar. That's probably not enough to strip out the holes unless you're using an impact driver or something.
    If you do lot's of partscasters and tinkering like I do, switching necks and bodies from this guitar to that one, the neck holes can get loose over time. I just break a toothpick to the right length and drop in the neck screw hole and it tightens right back up. I'm talking about partscasters here, not guitars worth a lot of money.
    G.Rotten, Boreas and P Thought like this.
  5. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    The neck was designed to be removable- Leo would be disappointed if they weren’t taken apart from time to time.
    Some sensitivity and decorum is necessary so as not to butcher the threads!
    JRapp and Boreas like this.
  6. tomkatf
    tomkatf Tele-Afflicted
    San Diego
    WAIT FOR IT!!!!...
  7. Boreas
    Boreas Tele-Afflicted
    Adirondack Coast, NY
    Changing strings causes wear as well. Best to avoid that. Not to mention - DON'T EVER UNDER ANY CIRCUMSTANCES TAKE IT OUT OF THE CASE AND PLAY IT!! It ruins many a guitar...
    SecretSquirrel and tubegeek like this.
  8. Boreas
    Ouch!
    Danb541 likes this.
  9. Boreas
    How does he know what his tech does when he is not looking?
  10. Boreas
    Some people never learned righty-tighty and lefty-loosy, or is it the other way around? I forget...
  11. rz350
    rz350 Friend of Leo's Ad Free Member
    Waubeka Wisconsin
  12. daddyplaysbass
    daddyplaysbass Tele-Afflicted
    Chandler Arizona
    "Chowder Up" - Band name alert ?
  13. Chuckboy
    Chuckboy TDPRI Member
    Jeddo
    Hello, Bill Kirchen.
  14. G.Rotten
    G.Rotten Tele-Afflicted
    CoolsVille
    The statement should be learn how to do what you need to do properly.
    The only reason I buy guitars that aren't set neck is so I can swap stuff at will.
    I have never once stripped a thread.
  15. JJLC
    JJLC Tele-Holic
    Midwest
    TMI :lol: .............
  16. Gary in Boston
    Gary in Boston Friend of Leo's
    WALTHAM MA
    I read a story once I think about James Burton and he'd travel with his Tele because he had to have that Tele with that neck he loved. After multi neck removals and re attachments he noticed things were getting, how shall I say a little sloppy. Sooooooooo he had threaded machine screw inserts installed in the neck heel and used machine screws going forward . I've removed dozens of necks of the the years and with common sense and the right tools it's not a big deal... at all
    Gary
  17. TwangerWannabe
    TwangerWannabe Tele-Holic
    West Coast
    Are you a collector or a player? Is the guitar something you're going to simply admire and look at and worry about it's collector's value, or are you going to actually play it and not worry about wear and tear? Some guitars you HAVE To take the neck off to adjust the truss rod. I use a pain lid opener to adjust the truss rods on most of my Fenders that have the adjustment at the heel, but some guitars (usually MIJ /CIJ Fenders) won't allow you to fit that paint lid opener in there and the neck has to be removed to adjust the relief.
  18. drmordo
    drmordo Tele-Holic
    Miami, FL
    This is exactly what I do, but I'd add that I think most folks try to put 100 ft/lbs of torque on neck screws. Snug is tight enough IMO.
    Boreas likes this.
  19. Kloun
    Kloun Tele-Meister
    Orange County California
    I have never stripped the screw holes on a neck. Even if I did, it would be a simple fix involving CA (Superglue).
    Boreas likes this.
  20. G.Rotten
    CoolsVille
    No doubt. I once played a guitar & then after that it was used. I tried & I tried, but it was never new again. On the next guitar I was very careful not to remove it from the case, only to find at the time of resale that it was still a used guitar somehow. Now I keep all my new guitars at the store. For the guitars that have already been removed from their original store safety shell, I remove & or replace however many parts I feel are needed because...........it's my guitar & I want to.
    Boreas likes this.
