Tag Strip build of a '63 Reverb Unit 6G15
Discussion in 'Shock Brother's DIY Amps' started by dougsta, Oct 22, 2021.
  1. dougsta
    dougsta Tele-Meister
    Edinburgh, Scotland
    I've always wanted a Fender '63 Reverb Unit so it was time to build one.
    As I have a lot of tag strips I thought I do a point to point build based on them.
    Here's the DIYLC design completed:
    Quite a simple build in the end.
    I used a long 2 spring tank 8Ω input like in the Fender Unit.
    I have a 10W SE OT from Primarywindings.com that is a good match:
    https://primarywindings.com/product/pwse10w5k0g/
    But I have it planned for a 6L6GC champ type build.. so then I remembered I have 6V6GT and OT from a 1950's radio OT, sounds good.
    Here's some sound clips of the final build.
    <iframe width="100%" height="300" scrolling="no" frameborder="no" allow="autoplay" src="https://w.soundcloud.com/player/?ur...ow_reposts=false&show_teaser=true&visual=true"></iframe><div style="font-size: 10px; color: #cccccc;line-break: anywhere;word-break: normal;overflow: hidden;white-space: nowrap;text-overflow: ellipsis; font-family: Interstate,Lucida Grande,Lucida Sans Unicode,Lucida Sans,Garuda,Verdana,Tahoma,sans-serif;font-weight: 100;"><a href="" title="Dougie Tamson" target="_blank" style="color: #cccccc; text-decoration: none;">Dougie Tamson</a> · <a href="" title="Reverb Test3" target="_blank" style="color: #cccccc; text-decoration: none;">Reverb Test3</a></div>
    and here's a full mixdown demo - 3 tracks of a Strat -> 63 Reverb -> audio interface, no digital effects, all reverb from the 63 unit
    <iframe width="100%" height="300" scrolling="no" frameborder="no" allow="autoplay" src="https://w.soundcloud.com/player/?ur...ow_reposts=false&show_teaser=true&visual=true"></iframe><div style="font-size: 10px; color: #cccccc;line-break: anywhere;word-break: normal;overflow: hidden;white-space: nowrap;text-overflow: ellipsis; font-family: Interstate,Lucida Grande,Lucida Sans Unicode,Lucida Sans,Garuda,Verdana,Tahoma,sans-serif;font-weight: 100;"><a href="" title="Dougie Tamson" target="_blank" style="color: #cccccc; text-decoration: none;">Dougie Tamson</a> · <a href="" title="63 Reverb Build Test" target="_blank" style="color: #cccccc; text-decoration: none;">63 Reverb Build Test</a></div>
    Now I'm thinking of expanding it to include a proper pre-amp, only need to add 1 or 2 12ax7's
    Doug.
    danfalck, as5431, Mike_LA and 7 others like this.
  2. mountainhick
    mountainhick Tele-Meister
    Rocky Mountains
    Very cool!
    Not sure why, but your soundcloud links were not visible to me in your post. They are when I hit reply and the message appeared in the write reply mode.
    Link
    Link
  3. dougsta
    Edinburgh, Scotland
    Thanks for fixing the links, very strange, that's the 1st time I've seen links disappearing.
  4. Mike_LA
    Mike_LA Tele-Afflicted
    Just past 11 on the Dial
    When I put my '64 princeton reverb in the closet for safe keeping, the only thing that I really missed was the reverb. So I ended up building 3 from weber kits.
    Love the 6G15, best of luck with your build.
  5. dougsta
    Edinburgh, Scotland
    I was going over my '63 reverb build and decided to add an EF86 to the 1st pre-amp tube triode and then spotted a mistake with my layout.
    V1 pin 1 should only be connected to the 100k resistor, I had it also connected to the 0.01µF cap, the cap should be connected at the other end of the 100k where it also connects to the 10k resistor.
    Here's the EF86 fitted (I had already drilled a hole and added spare socket to try an EL84/EL83 as the reverb driver)
    Nice set of old Mullards and an old USSR 6V6
