switching between channels deluxe reverb
Discussion in 'Amp Central Station' started by texmck54, Oct 2, 2010.
  1. texmck54
    texmck54 Tele-Meister
    Port Dover On. Canada
    i have a handwired version of the deluxe reverb the normal channel
    is a kendrick mod tweed version & the vibrato channel is
    a blackface version is there a AB box to switch between these
    2 channels
  2. Singin' Dave
    Singin' Dave Friend of Leo's
    Chicago
    There are many. I would get an ABY pedal so you can switch between channels or run both at the same time if desired.
    The one I recommend is the Radial Bigshot ABY - passive (no power needed), compact, solid as could be and has important features like ISO, ground lift and phase reversal, which is more important when running two different amps together, but still great features only found on the nicer ABY boxes. They are bit more than the cheap Morley and Whirlwind ABYs, but so worth it. A nice amp like that deserves the right stuff.
  3. xstrada
    xstrada TDPRI Member
    san juan
    Is there signal loss using an aby box in an amp like deluxe reverb?
    Does the aby box have to have a buffer or is it not necessary?
  4. printer2
    It is just a switch determining where the signals go. Should have no more effect than plugging into the amp jacks.
  5. DrPepper
    DrPepper Friend of Leo's Ad Free Member
    So, how is it? Would like to see pics... Who built the amp?
  6. Watchdogg
    Watchdogg TDPRI Member
    Alexandria
    I use a Fender aby to switch normal and vibrato channels also works upload_2020-10-18_12-29-49.png using two amps.
