Switchable Impedance Cabinet
Discussion in 'Amp Tech Center' started by DCW74, Oct 24, 2018.
  1. DCW74
    DCW74 Tele-Meister
    Columbus, OH
    If I want to make a 8 ohm to 16 ohm cabinet, would it be possible to just add a switchable inductor in series with my existing speaker?
    For example, I have an Eminence Legend 1518. The nominal impedance is 8 ohms. DC resistance is 7.16 ohms. Resonance is 82 Hz. A 13.9 mH inductor has a resistance of 7.162 ohms at 82 Hz. So shouldn't I be able to add a DPST on/on switch in series with the inductor to double my impedance? In doing so, would I be able to keep the dynamics of my original speaker intact?
  2. fmmlp
    fmmlp TDPRI Member
    Buenos Aires
    Probably your speaker will sound different with a random inductor in series. If such inductor has a series R near 8 ohms, why not add a non inductive R of 8 ohms in series?
  3. DCW74
    DCW74 Tele-Meister
    Columbus, OH
    I'm just trying to figure out a reactive load. So I'll probably just end up sticking with a smaller speaker to put in there. I tend to make things more difficult than necessary.
  4. noah330
    noah330 Friend of Leo's
    Maryland
    DCW74 likes this.
  5. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    DCW74 likes this.
  6. darren7
    darren7 Tele-Holic
    Toronto
    With multiple speakers, it can be done by running the speakers in series or in parallel. I’m not sure how one would go about making a multi-impedance cabinet with only a single driver.
  7. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    Would an inductor rated for the power handling that you'd need be that much cheaper than an additional speaker?
    As far as the speaker sounding the same, I can't imagine how it would. And even if it sounded similar enough, the amp would certainly sound different between the 8 and 16 ohm taps on the OT. What about the heat generated?
  8. gusfinley
    gusfinley Tele-Afflicted
    SLC, UT
    The question is why? Are you trying to go for impedance matching? Do you need the full 150 Watts possible? Is this with a solid state or
    For Quick and dirty, you could just put a 150 Watt 8 ohm resistor in series to get "16 ohms." A resistor in series shouldn't have much of an affect on tone.
  9. DCW74
    DCW74 Tele-Meister
    Columbus, OH
    To answer the question of why: I just want to experiment with different ways of accomplishing the same goal. I have an equal amount of fun figuring this stuff out as I do playing with my creations.
  10. VintageSG
    Yorkshire
    DCW74 likes this.
  11. DCW74
    DCW74 Tele-Meister
    Columbus, OH
