Switch signal straight to Jack?
Discussion in 'Tele Home Depot' started by Chordophonic, Jun 25, 2014.
  1. Chordophonic
    Chordophonic Tele-Meister
    Isle of Wight UK
    So, I have a Franken Tele single pickup, 3 strings, one volume, open tuning and I would like to fit a switch to bypass the volume so the signal can by-pass the volume pot. Like a solo switch….I can solder and understand a wiring diagram to a degree, but am otherwise as much use as a chocolate teapot with regards to working it out myself……
    Could someone help me out with a drawing and tell me what sort of switch I need please?
    Thanks!
    Paul
  2. Mark Adkins
    Mark Adkins Tele-Meister
    Petoskey, MI
    I was originally going to suggest a no load pot, but upon reading the description further it states it cannot be used as a volume pot. Sorry.
  3. waparker4
    Philadelphia, PA
    SPDT switch.
  4. ecoli
    ecoli Tele-Meister
    Alberta, Canada
    I was thinking the same thing. Not sure why you can't use it as a volume pot. Would be the easiest solution by far.
    I'm no help :p!
  5. waparker4
    Philadelphia, PA
    DPDT solution (slightly more brighter)
  6. Mark Adkins
    Petoskey, MI
    I was curious why myself, so I researched it further.
    From what I understand, 0-9 works fine, but when you click into 10 it breaks the circuit completely and you get no output to the amp. It's a good solution if you want a kill switch incorporated into your volume pot. :lol:
  7. waparker4
    Philadelphia, PA
    ACtually I don't think it would work at all.
    The pickup signal comes into the 1st terminal which has been disconnected from the rest of the carbon track. So no signal makes it past that point to where the wiper is
  8. Mark Adkins
    Petoskey, MI
    Hmm... When I was researching why it wouldn't work, I came across a thread on the Seymour Duncan forum, in which they said it would work 0-9. I have never tried it, so I can't say for sure that it will.
    Having said that, I trust your expertise with wiring and believe you when you say it won't work at all.
    The kid in me still wants to try it just to see what happens! :lol:
  9. Mark Adkins
    Petoskey, MI
    Just found another post that says 0-9 will work, but this post goes on to state the pot would work backwards, in which you are at full volume in the full counter-clockwise position, and the volume drops as you turn clockwise, and disconnects altogether when you click into the no-load setting (10). There goes the integrated kill switch! :lol:
  10. Chordophonic
    Isle of Wight UK
    Thanks!
    Paul
