Swimming Pool resonance
Discussion in 'Tele-Technical' started by Shango66, Apr 6, 2020.
  1. Shango66
    Shango66 Friend of Leo's
    Hi all.
    Got a large swimming pool route in my partscaster strat.
    It’s been a beater/ try out guitar for many years.
    I dragged it out recently and noticed when goosed with gain a high pitched ring that is noticeable after the notes play out, it’s a milsec long but it’s there. This occurs regardless of the pickups used.
    I’m beginning to think this could be because the scratch plate is essentially a drum head floating over the pool route and the vibration is causing the ringing in the same way a drum would.
    Anyone experienced this?
    S
  2. galaxiex
    galaxiex Tele-Afflicted
    Edmonton, Alberta Canada
    Does the Strat have a trem?
    One or more trem springs ringing?
    teleplayr and Shango66 like this.
  3. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    You're probably hearing some of the strings ringing above the nut. Wrap something around the strings up there, and listen again.
    Shango66, Jakedog and galaxiex like this.
  4. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    My guess is trem springs as well.
  5. Jakedog
    The North Coast
    Yep. Sounds like sympathetic ring from behind the nut.
    I’ve also heard Trem springs do it. I use five springs and screw the claw all the way in, cause I hate trems, but don’t think hardtail strats sound right. I’ve had the springs make some pretty weird noises. Now I just lay a little piece of foam in the trem cavity before I put the springs in. Works like a charm.
    Shango66 likes this.
  6. TimTam
    TimTam Tele-Holic
    Melbourne
  7. Shango66
    Thx All.
    It was the nut!
    I put a piece of rubber hard up under the strings and “ just like that” it’s gone.
    Proves yet again, if the answer is not found here, there is no answer.
    Tommy Biggs likes this.
