swells with volume knob
Discussion in 'Tab, Tips, Theory and Technique' started by jwmanz, Oct 9, 2017.
  1. jwmanz
    jwmanz Tele-Meister
    Indiana
    I would like to downsize my pedal board and the my volume pedal is a large, underutilized pedal. However, it is really handy when I need to do some ambient swells. I just can't seem to pull off a swell fast enough on my Tele. I guess this is a bit of a silly question, any tips to pulling off swells with my volume knob?
  2. 68tele
    68tele Friend of Leo's
    East Northport NY
    Hmmm...I just wrap my pinky around the vol knob - never been an issue, but then again my fingers are a foot long.
    Practice is the key.
  3. jwmanz
    jwmanz Tele-Meister
    Indiana
    Yeah, I do have a short pinky. And I feel like the taper on the volume is too long to get it from 0 to 10 in one motion.
  4. Old Tele man
    Old Tele man Friend of Leo's
    Once banned always banned
    For clean finger swells, the pot MUST have 'smooth/low-resistance' rotation. If there's a felt washer under the pot knob, think about removing it, and definitely "lube" the pot guts for cleanliness and reduced friction.
  5. Flyinlow
    Flyinlow Tele-Meister
    NE Indiana
    I just roll across my pinky and ring finger. After doing it for many years, I've learned to accurately hammer (and mute) as I want with my fretboard hand. Takes some practice, but no big deal.
  6. Cheap Trills
    Cheap Trills Tele-Meister
    Brooklyn, NY
    Have you considered flipping your control panel so the volune is closer to the bridge?
    Modernelove and Modman68 like this.
  7. jwmanz
    jwmanz Tele-Meister
    Indiana
    Ok, another stupid question, but do the silver knobs just come off if I pull hard enough? I'm at work at the moment so I can't reach for my guitar.
  8. jwmanz
    jwmanz Tele-Meister
    Indiana
    Is it as simple as unscrewing the panel and flipping it or the wires need to be re-soldered?
  9. Cheap Trills
    Brooklyn, NY
    It matters how it's wired right now and how much slack there is. You could open it up and just see if you have enough slack in the wires to move things around. You'll want to remove the pots and switch from the control plate, flip the plate, then see if you can move things where you want them without re-soldering. Don't forget to flip the switch so the pickup positions make sense.
  10. Old Tele man
    There's a set-screw in the side of the metal silver knurled knob.
  11. Obsessed
    Montana
    It is the main reason I have the reverse control plate, but nevertheless, I still like my volume pedal for awesome swells and fade outs. Keep the tank and I know it can't be as large or heavy as my Fender Classic RI.
  12. Hexabuzz
    Hexabuzz Friend of Leo's
    Northeast PA
    Like any other technique, have you practiced it?
    Or did you just try it a few times and felt it wasn't working out?
    You certainly may need a new/different volume pot, but like any other skill on the guitar, it takes time to master.
    Before you start changing things, just work on it as part of your practice routine for a week, and then if it's not what you want it to be, think about a hardware change. Even if you go that route, you will have improved your skill at it.
  13. Dobronaut
    Dobronaut Tele-Meister
    Leicestershire UK
    You need a Strat! It's the only thing it does better than a Tele. My short fingers are just not comfortable on a Tele when doing swells, even with the control plate flipped.
  14. Junkyard Dog
    Junkyard Dog Tele-Afflicted
    In this video, Bill Kirchen describes how to flip the control plate, exchange the volume and tone knobs, and flip the selector switch. It sounds easy to do! He also demonstrates his volume swell technique after switching everything around.
  15. Brokenpick
    Brokenpick Tele-Afflicted
    Dixie
    Practice IS the "key" of course.
    But some things may be helpful. Different knob knurls, different pots, flipped control plate -all may give you the feel you need for improved practice.
    One tip I got from a VERY skillful player might help:
    Make sure you pick the strings SOLIDLY before rolling the swell up. This may need to be a sort of exaggerated attack. The strings need to be hit hard enough that they'll be ringing well as your roll the volume up. Otherwise you loose sustain before the swell effect is realized.
    (I haven't practiced this enough to excel at it, -but practice and a firm, controlled attack do seem key...)
    MickM likes this.
  16. littlebadboy
    littlebadboy Tele-Afflicted
    Midwest, USA
    Keep your volume pedal.
    BuckSatan likes this.
  17. 24 track
    kamloops bc
    I reversed the control plate so it is volume , tone, switch , so I could do swells with my small finger.
    I have a volume pedal but it is huge as you said, and I dont like the travel on the pedal to get the effect i want ,I may have to adjust the rise of the pot so the motions are not so animated to use it.
  18. Budda45ftw
    Budda45ftw Tele-Meister
    Rochester NY
    Yep. Also consider getting a log taper pot.
  19. littlebadboy
    Midwest, USA
    I use my "slow gear" function on my Boss GT-1. Of course, there is an individual pedal, the Boss Slow Gear SG-1.
    I demo'd the slow gear of my GT-1 here: (Go straight to 1:13)
    Good luck!
  20. rburd2
    rburd2 Tele-Afflicted
    Georgia, US
    Granted, I can't actually do swells without touching the volume pot, but I never touch it. No volume pedal. I'm a rock guy by default. I vary volume by pedals and pick attack.
